- Year
- 1999
- Vehicle Model
- 100 Series
- Mileage
- 144755
- Color
- rgb(9, 8, 8)
*****Accepted and started listing process on BAT. No longer for sale. Will post link when it's live. It will be no reserve so anyone who appreciated the build I would be very grateful for your support when it's live even if it's only a positive comment or question.GCC Spec 5 speed Supercharged triple locked UZJ100
Any advice for videos , missing info, or pics greatly appreciated even from non-buyers.
Once auction approves listing I will post link and any offers will have to go through auction.
Lots of info of build on mud and other Facebook groups. If you have any questions or I can help with your similar build feel free to PM me anytime.
Was built by me while living in Dubai. It was my daily for last 4 years before importing it back when relocting home. Louisiana title now in hand. Already registered and plated for test drives.
Love it or hate it, It is one of a kind.
Needs a new home. If i had a place to keep it I would but gotta let it go. I would like to stay in touch with new owner and follow where they take it from here if possible.
Looks , Drives, and sounds pretty much stock as a daily. Didnt build it as a race car and I wouldn't consider it crazy fast. Built and tuned with focus on reliability and driveability. But it is very strong and way faster then stock.
1999 Toyota Land Cruiser - GCC Spec
232k KM (144k miles) miles
2uz V8 – Harrop Supercharged 2.6-liter (+500 whp)
5 speed manual (H151F) Swap
Triple locked – Stock E-Rear /TJM Front -Air
Engine fully rebuilt and upgraded with Forged Internals - (October 2023)
-Built by Subzero Motor Sports in Dubai (@subzeroracing) Feel free to message them and ask about the build on Instagram.
Brian Crower forged rods
Manley forged pistons (+.25mm stock CR)
ACL full bearings set
Arp rod and crank bolts
Arp head stud kit
OEM Gasket Set
Cylinder heads rebuilt
Crank balanced
OEM Timing Belt set
OEM Coil set
OEM Water pump
OEM TRD thermostat
OEM Fan shroud and coolant res
OEM Under hood insulator
OEM Oil pump
OEM Fan clutch bracket
Harrop 2650 Supercharger (Feb 2024) *To Date this is the only known 2.6l SC 2UZ LC
Custom built by Elate Manufacturing (@elatemfg) I'm sure Travis owner of Elate wouldn't mind a message asking about my build.
Elate + Griptec custom 65mm pulley (17 psi boost)
Elate idler bracket
Elate 60mm upgraded intercooler Manifold
Pierburg cwa100 High flow intercooler pump
Front mount Heat exchanger
MSD solid state relay power module
Maxxecu sport ECU with Bluetooth and Wideband Control
Pioneer Head unit w/ removable Tablet (ECU control)
Phormula knock monitor System
Elate fuel rails
Injector Dynamics 1050x fuel injectors
Bosch dbw 82mm throttle body
Walbro 450 fuel pump
OEM Coil Set
Radium braided fuel line kit
Radium fuel filter
Radium fuel pressure regulator
Radium catch can
Radium Fuel Damper
Bullet custom long tube stainless headers
Bullet custom 3" stainless downpipes
Bullet custom full 3" stainless exhaust
Stock rear resonator
Exhaust Custom built by Bullet Performance in Dubai (@bulletperf.dxb)
*Sounds like stock V8 at idle and cruise with zero drone. Aggressive when on the gas.
Manual swap- all new oem parts used for swap with a used H151f gearbox
H151f 5 spd manual - ( new bearings + seals 2024)
-New pedal, master/slave cylinder/ oem clutch lines , shifter linkages etc. Even swapped in stock manual dash faceplate.
4terrain ultimate heavy duty clutch kit
Cruiser outfitters part time 4wd kit
Aisin Locking front Hubs
OEM Steering rack and pitman arms
OEM Power steering pump w res
OEM Front upper and lower control arms
OEM Front stabilizer bushings
Front diff rebuilt
Front TJM air locker with air pump
CV joints full rebuild
Front wheel bearings
OEM Front prop shaft
OEM Rear prop shaft
OEM Rear upper and lower control arms
Toughdog shocks
OEM Headlights, Corner markers and rear hatch light
OEM All chrome seal trim replaced
OEM 4 Wheel lug covers
OEM Front and Rear Gold emblems
-Non- OEM Parts
Front grill
Front and Rear Wheel Spash Guards
Front bumper cover
*All parts installed within the last 3 years. Engine and Transmission 2023
Plenty of small scratches and nicks stains etc for a 25 year old car. I didn't have it repainted but looks like it was before I bought it 4 years ago. Paint jobs aren't to expensive in Dubai. Paint looks great when cleaned up. I did have wheels repainted with new oem center caps.
Feel free to ask me anything about it or specific videos. Won't hurt my feelings
Arp head stud kit
OEM Gasket Set
Crank balanced
OEM Timing Belt set
OEM Coil set
OEM Water pump
OEM TRD thermostat
OEM Oil pump
Elate idler bracket
Elate fuel rails
OEM Coil Set
Radium fuel filter
Radium catch can
Radium Fuel Damper
Front diff rebuilt
OEM Rear prop shaft
Toughdog shocks
-Non- OEM Parts
Front grill
Front bumper cover
