SOLD Los Angeles: 2000 Lexus LX470 Modified Build.
Status
Not open for further replies.
Year
2000
  1. LX470
Los Angeles, California United States
Mileage
174000
Color
rgb(255, 174, 0)
Thank you for looking.
Selling to fund a house.
Here’s the build list:
Please share, thank you.
Replaced at 150,000 miles
-Timing belt $1000
-Water Pump done with Timing Belt
-Serpentine Belt with Pulley
-Fuel Filter
-Valve Cover Gasket
-NGK Ruthenium Spark Plugs
-New 3 Row Radiator 50/50 Coolant
-Engine mounts
-Transmission mount
-OEM Thermostat
-Lower Control Arm Ball Joint Replaced 555
-Total Chaos Upper Control Arms $900
-Tough Dog shocks 41mm fronts and
the rears are 45mm adjustables. $1000
-OME 2863 Rear Springs and OME Front Torsion Bars $200
-SPC Rear Lower Link $200
-Ironman Rear Upper Link $200
-Trail Tailor Rear Shock Guard, Rear Lower Link Guard, Extended Front and Rear Sway Bar Links
$300
-PIAA Horn
-HID Headlight Retrofit Morimoto/LBBuiltwerks $800
-Kenwood Apple Car Play Stereo with new Amp
$400
-Weather Tech Mats 3 Rows
$300
-Replace Brake, Steering, Front/Rear Diff and Transfer case fluid.
-New Rear Brake Set
-New OEM Front Brake Pads
-Rays Volk Racing TE37x 16x8 5x150 0 Offset (5) $3000
-Tires are Toyo Open Country AT2 Extreme 295/75r16 (5) $1000
-Prospeed Roof Rack with 42” double row lightbar, side camp lights, rear chase lights, 100w solar panel with switch pod. $900
-LED Interior lights
-Dissent Steel Front/Rear Bumpers and Aluminum Underbody Skids with 2 LED backup lights and rear LED plate light with flip up front plate. $6000
-Warn Winch VR10-S Synthetic $500
-Diode Dynamic Stage Series SAE 6” Amber Fog Lights (2) $200
-Baja Design LP9 Pro (2) $1000
-OEM Steering rack with new hose, Nolathane polyurethane bushing, reservoir, and pump. $1000
-CV boot change inner driver side. $200
-Back up camera relocation. $150
-Rewire bumper backup lights to go on automatically when reversing. $100
-Hitch Wiring to new bumper.
-Aisin Part time drive. $1000
-Denso Starter.
-Denso Alternator.
-Denso Fuel Pump.
-Side marker lights LED.
-ABS wiring replaced OEM.
-Dual Battery with X2 68AH, Redarc 1225d, and solar panel $1000
-Scheel-Mann seats $5000
-Prospeedrack rear drawers
-3M Crystalline windshield and front windows tinted. $300
Conservative Total not including labor and time piecing all the parts together: $28000
174,000 mile 2000 LX470 valued at around $15,000
Looking to get around 50k for it. Thank you.
There is some value in a rig that is 100% done and ready for 100k miles of work and play.
Is my math off, or is that $43K? So, full retail on everything including labor, and high retail on your truck, plus $7K?
You can try building that rig now with the updated prices today and see how much it will cost you DrChris. Labor is not included, time, and researching to make everything whole. Thank you for chiming in.
Looks clean! How did you pass smog with the Doug Thorley Headers? Trying to get some for mine but it's not California Legal and don't want to deal with the hassle of replacing back to stock if I get hit for it.
Thank you.
Status
