Looking for help rough running (1 Viewer)
Frankly I don't believe it's a fuel issue but who knows?
And your ignition sounds like it's all new, fresh and clean. What is it timed at right now? I would imagine yours needs a bit more advance than the book calls for, especially without the vacuum advance?
Take your carb cleaner or brake cleaner can and soak everything that ever had vacuum in it from your vacuum advance to your brake booster, carb, emissions valves, everything. If you find the leak then your rpm will increase.
Any chance you got a tank of bad gas?
Run the valves again and if in doubt set them up on the looser side. Do each one at TDC compression...
