Im sure this has been covered but anyway I was going to get a lift kit from TPI(2.5-3") until I came across this one from man-a-fre. This is for my FJ62. Does anyone know if there has to be any special mods done to install this 4"kit with the reverse shackle thing? Does this kit appear to have everything I would need or would I also need like 2 or 4 degree shims as well? How would the extra height affect the driveline and such with potential problems like vibration? Forgive all the questions but Im paranoid about getting a lift put on and not being aware of what problems I might run into or not having all the proper parts. Is there much diffenence between these two types of lifts in the way on performance or ride quality???
[glow=red,2,300]The ultimate suspension system for your FJ60. Included in this kit is everything you will need to install a high quality long travel suspension system with 4" of overall lift, extend your brake lines, properly reposition your front sway bar end links, and reverse your front shackle to the rear of the front leaf spring. The improvement in ride quality and control is amazing. Kit includes 4 Safari lifted leaf springs, 4 Heckethorn, or Old Man Emu Shocks, front Shackle Reversal Kit, 2 rear 4+Plus Greasable Extended Shackles, 4 Greasable Spring pins, 8 new U-bolts, Old Man Emu Steering Dampener, 2 front extended sway bar links, front and rear extended DOT stainless braided brake lines, 16 spring bushings & 8 shackle bushings.[/glow]
