sandcruiser
....back in the saddle again....
Hi all
I'm trying to replace the lock cylinder on my hj60. Long story short: the key is bald. I'd like to swap in my fj60 cylinder
problem is: on the fj and the FSM it shows the little pushbutton on the front- just insert key, turn to ACC, push button with wire/punch then remove cylinder
Not working.
It appears that there is no button on the hj's cylinder
Further: on the fj, the back of the housing has a hole to which is mounted the door-beeper switch. On the hj, there is no switch and it feels like there is a plug there.
Anyone with no door beeper out there know if the factory plugs that hole?
Or did a 'mechanic' down here use that plug to hold in the key cylinder (which would be a huge PITA for me)?
thanks!
Not working.
thanks!
