LJ78 parking brake options
England
The parking brake / hand brake on my LJ78 has always been rubbish, it will work great for a short time, but will then stop working even after replacing all the shoes and disc/drum.
So I have been looking at alternatives, and the two I can find are:
1. Fit a transmission brake - I don’t really like this as they are not as effective as a wheel brake.
2. ⁠fit different rear brake calipers that have a built in park brake - this is my preferred because it’s less brake to service.
Has anyone found something that fits straight on?
I rear a thread a while ago that said Toyota Avensis caliper will fit with a small about of work, and will also allow me to keep the original carrier so I can still use my standard pads, so after waiting a while I got a cheap set from eBay to see if the will work.
Today I got the chance to take a look as I needed a quick brake check for my MOT.
I will have to have new sliders made to make the caliper line up (not really a big issue) but annoyingly the caliper is not wide enough to take a new set of brake pads.
Hello,
The parking brake slips in old age.
It is necessary to inspect and repair the cable, brake shoes, springs and links as needed. It is easier than modifying.
If you have the FSM, you can do the job yourself. The search function in this forum is your friend.
Parts are available from Toyota.
Juan
Hello,
Juan
Thanks Juan,
The work to repair the factory park brake is no problem from me, I would just like to find a more reliable solution that requires less maintenance.
Thanks Ash
Hello,
The factory park brake is reliable. All it needs is a good overhaul.
There is no need to modify.
Juan
If you take the time to read the factory service manual for 70 or 80 series rear disc brake parking brake setup and repair procedures, and follow them to the letter, your parking brake will work very effectively.
It’s also very important to ensure the parking brake bell cranks and pivots move freely and are lubricated properly, and that the hand brake cable and the linkage free play in the drums (adjusted by the screws at the rear of the backing plates) as well as the shoe to drum clearance is set properly.
Then, follow the correct break in and bedding procedures and readjust the shoe clearance and cable tension after bedding/break in.
~John
~John
Hi thanks for the info, I think my original post was a bit misleading, I have no issues with getting it to work and when set up it works well, unfortunately the drum design holds the mud in so if I want to keep it working I have to take the wheels and discs off to clean them out every time I go off road (as it’s only a toy and not a daily that’s pretty much every time I use it)
I will keep working on a solution and will post up the info incase it helps someone else out in the future.
Indeed, mud can be a huge problem with certain brake designs.
If you figure out a caliper with an electric park brake function or a mechanical function, I’d like to see it.
~John
So I have finally got round to looking at this, after searching through about 1600 different brake caliper technical drawings I have eventually found something that could work. I have had to make a compromise on the piston diameter, standard is 53mm and the biggest I could find that matched all other Criteria was 43mm, but these calipers are from a large German car with similar disc diameter.
Anyway today I managed to test fit and…. It fitted!
So I am using the factory stand brake pads and carrier, I had to find some slider pins, the Toyota ones are 9.5mm and the only ones I could find were 10mm so had to turn them down to fit.
I will need to move the lower shock absorber mount as the caliper hits the shock absorber ( I thought it might) and I may have to run the calipers the wrong way up to make it all work.
So next jobs are:
- Move the lower shock absorber mount
- New discs and pads
- fully installed the calipers
- install the handbrake cable (lever end will take some engineering)
- check break performance
Once I’m all finished I will do a write up with a parts list.
I´m on the process of doing the same parking brake upgrade on my 94 HDJ80.
Do the Audi 100 calipers bolt straight into the Toyota caliper carrier? Do the Audi sliding pins need machining or the toyota ones?
Keep us posted please, this might be the sigth solution for the OEM handbrake nightmare...
I’m looking forward to seeing what comes out of this. I’m still having trouble my handbrake working correctly after replacing the shoes and the guts, so have ordered all of the other mechanical parts (bell crank, pins, et cetera).
