LJ70 front brakes pulling on one side
Malta
Hi,
I have a 90 LJ70 sqaure headlight with a 2.4TD (2LT) engine, i was wondering if I am correct in stsrting to diagnose where I have an issue. One of my problems at the moment are my brakes, when i hit the brake pedal the car pulls on one side(right) and if i press a bit hard the disc squels a lot as the right side (driver side) is considerably more worn than the left.
First assumption without checking is stuck/worn passenger side calliper so a caliper rebuild would help.
Anything else i should have a look at.
P.S. brake master is new and system bled properly.
Regards,
Kyle
Yes, I'd agree that it's likely a caliper issue. I'd suggest rebuilding (or replacing) your calipers, and replace disks and pads too.
I rebuilt my calipers when I first bought my LJ78, and they've worked great since. My rears were seized at that time.
