List of high-quality aftermarket replacements LC80
Qatar
With OEM parts becoming harder to find, often overpriced, and sometimes poorly stored, high-quality aftermarket replacements are the smarter choice. Many match or exceed OEM in strength, fit, and modern features.
This list helps current and future LC80 owners source reliable, long-lasting parts — and modernize where possible.
How it works:​
  • Parts marked TBD (“To Be Determined”) mean no confirmed high-quality aftermarket replacement is known yet.
  • Please comment with brands or info you know so the list can grow.
  • Focus is on Australian and other reputable manufacturers, excluding Japanese OEM suppliers.
  • All parts should be plug-and-play (fit OEM mounting/connection points) unless noted otherwise.
Mechanical / Driveline​
  • Brake rotors – DBA
  • Brake calipers – DBA
  • Driveshafts – Terrain Tamer
  • Differential housings – DWIZ
  • Front LSD differential – TBD
  • Rear LSD differential – TBD
  • Steering knuckle – Front Range Offroad
  • Swivel hub seal kit – DWIZ, Front Range Offroad, Terrain Tamer, Sumo Gear
  • Front axle CV joints/shafts – RCV Performance, DWIZ
  • Rear axle shafts – RCV Performance, DWIZ
  • Steering box (LHD) – Red Head Steering Gears
  • Steering box (RHD) – Red Head Steering Gears
  • Steering arms (upper & lower) – Slee Offroad, Front Range Offroad
  • Tie rod & drag link assemblies – Ironman 4x4, The 4WD Shed, PSR
  • Dust shields (brake backing plates) –Front Range Offroad
  • Bodymount bushings – Flatout Offroad, Ironman 4x4, All Four x4
Fuel System​
  • Fuel tank (Long Range, No spare wheel) – Long Ranger, Brown Davis
  • Fuel tank (OEM style) - TBD
  • Fuel pump –All Four x4
  • Fuel pump strainer/filter – TBD
  • Fuel sending unit (level sensor) – All Four x4
  • Tank straps & mounting hardware – Long Ranger, Brown Davis
  • Fuel filler neck assembly (hoses, cap) – TBD
  • Axle breather – SAAS
  • Evaporative emissions canister (charcoal canister) – TBD
Cooling & Fluids​
  • Radiator (HD standard thickness, no excessive heat issues) – TBD
  • Radiator (Thicker) - Terrain Tamer
  • Fan clutch assembly – TBD
  • Brake fluid reservoir – TBD
  • Windshield washer fluid reservoir – TBD
  • Windshield washer fluid pump - All Four x4
  • Coolant reservoir tank – Panel House, Auto Parts Supply
  • Power steering fluid reservoir – All Four x4, AlliSport
Body & Exterior​
  • Side steps (OEM stlye) - TBD
  • Front fenders – TBD
  • Rear fenders – TBD
  • Fender flares (OEM style) - TBD
  • Fender flares (40mm wider) - Repliglass
  • Fender flares (95mm wider) - PSR
  • Fender flares (125mm wider) - Tough Toys
  • Hood – TBD
  • Hood (Fiberglass, scoop, no emblem hole) - The Fiberglass Factory
  • Hood struts (gas shocks) – Cruisercrops, All Four x4
  • Tailgate/back door gas struts – Cruisercrops, All Four x4
  • Roof panel – TBD
  • Sunroof glass (blue & bronze tint) – TBD
  • Windshield (blue & bronze tint) – TBD
  • Side windows (blue & bronze tint) – TBD
  • Tailgate glass (blue & bronze tint) – TBD
  • Side chrome trim (roof line) – TBD
  • Door chrome trim (upper) – TBD
  • Door lower grey trim – TBD
  • Headlights (OEM style) –Lightwerkz
  • Corner headlights - TBD
  • Side mirrors – TBD
  • Emblems – TBD
  • Bumpers (front & rear, OEM style) – TBD
  • Bullbars (best looking ones, with flares) - Kinselas, Precision
  • Door handles (chrome/better quality) – TBD
  • Windshield washer nozzles (water spray jets) – All Four x4
  • Washer hoses (under-hood routing for spray system) – TBD
  • Battery terminals/fingers –Slee
  • Wiring harness clips and mounts (OEM style) – TBD
Interior​
  • Dashboard – TBD
  • Steering wheel – TBD
  • Instrument cluster (digital) – Elitedash, Dakota digital RTX
  • Instrument cluster (Analog) – TBD
  • Door panels (OEM style) – TBD
  • Roof headliner – TBD
  • OEM-style switches – TBD
  • Stereo (OEM look, modern internals) – TBD
  • MTM gear lever – TBD
  • Carpets –Auto Custom Carpets, Tru Fit
  • Floor Mats – TBD
  • Pedals (all three) – TBD
Electrical​
  • Fuse box (OEM fit, higher capacity) – TBD
  • Complete wiring harness – TBD
  • Relay box – TBD
Add Dakota digital RTX for OEM look gauges
Terrain Tamer's knuckle/swivel hub kits are excellent quality, all bearings are koyo.
Auto Custom Carpets (ACC) can do the carpets, mold fit. Not perfect but best option on the market.
