Light/High Beam Dashboard Indicator (1 Viewer)
North Carolina
i tried looking around the forums for this, maybe someone can direct me, but the summary of the issue is none of the front headlights on and high beam indicators on the dashboard show up. The lights do work just fine, just the indicators not showing up on the dashboard. Any ideas how to debug this?
Thank you
There is no indicator for low beam unless the early LC clusters are different than the later ones. The high beam indicator is a bulb and is likely just burnt out. You'll need to remove cluster and replace bulb. There are some good videos on youtube on how to remove the cluster but it's pretty easy.
Easy enough - i really though when maybe the fog lights and the low beams would have an indicator.
Ill check out the bulb situation then
