Let's see your DIY rear storage / drawers
Budget build my son put together. Very stout, because he had to store work related gear (he's a police officer).
The internal framework is perforated 1/8" steel angle and the hardware is from storage containers for music gear for roadshows.
If fits between the wheel wells with no space and extends from the flipped middle seats to the tailgate. The height is just shy of the tailgate to allow stacking on top which the cargo nets secure. We left it shy so that if anything happened to get free, it wouldn't have to rely on the glass to stop it form joining the tailgating driver.
hmm, wonder what I need to do to fix it......in the meantime, let me copy/paste the language here. The pics are not as easy as copy/paste as it used to be here and I don't feel like putting for the effort but let me see if can do snippet.
copy/paste
There are some seriously talented folks on here. My storage solution is basic but very robust for my needs.
- 10g water bladder under the second row platform which houses a fridge and a "snack" box with open top for accessing while driving. The water bladder implodes into itself, which keeps the water sloshing to a minimum. Our duffle bags sit next to the snack box.
- cargo area has two drawer system made out of alum and they contain all recovery gear and tools. This area also houses a kitchen, one 5gal potable water can and a 10# alum Worthington propane tank.
- Under the RTT are two storage compartments (you can make them out in the pic with the RTT deployed) - the fwd compartment under the RTT houses the awning walls and misc soft items. The rear compartment under the RTT houses a DIY alum table. Both compartments are lockable and accessible from both sides of the vehicle. These are made out of bend 1/8" alum, nothing fancy.
- The cargo attic holds soft stuff like jackets and such. I'm using a 48" Metra food shelving that spans both sides of the cargo area.
- There is also a permanent dog bed next to the kitchen box in the cargo area. A no spill water bowl lives there as well.
-Kitchen drawers made of 12mm Birch plywood, and have no slides, simple wood on wood action. Drawers are lined with adhesive backed foam on the top and sides. Corrugated plastic is used for separation and to keep the rattle to a min. The whole kitchen fully loaded probably checks in at 100#, just a WAG on my part because most of two 4x8 sheets of Birch plywood were used. This box houses all kitchen stuff, including the stove and the RTT ladder. A ladder with muddy feet is no longer an issue! On the right side open compartment the rtt ladder is housed. On the top open compartment there is a two burner stove, and an area rug.
-There is a slide out (more like, rotate out) tray under the fridge that is used to temp hold food during loading/unloading the fridge. You can see a hose in the same area and it is connected to the water bladder for dishwashing. The tray also holds clean dishes during dishwashing.
- A handwashing station is always ready with a soap dispenser on the door, next to the fridge, along with a towel. So nice to wash hands at a moment's notice before making a samich.
- An utensil holding system made out of thick canvas is attached to the left side of the kitchen. Each utensil has its own compartment, which eliminates any rattling and also promotes quick access for roadside lunch action. Knives and a medium size cutting board live here as well. My daughter is amazing with a sewing machine!
- Alum cargo drawers hold all recovery gear, including front+rear driveshafts, axles, one birfield, various hardware, welder, jumper cables, spare fuel pump, fusible links, bottle jack and a good assortment of metric tools.
All this took 17 years of tweaking and finally, has reached a plateau. No more frustration from digging for stuff, re-arranging things, etc. Vehicle is always ready to serve. Yes, she's a heavy pig at 7200#! The cargo barrier is from AUST and it's super convenient to hang hydration packs, bungee camping chairs, first aid kit, etc on the forward facing side.
Let me know if you have any questions.
Ok, that's genius. We run our fridge like that, but on the other side - and could definitely use that table surface solution!
I've probably spent a little more time on this that I should have.
But here is my DIY rear storage system. Certainly inspired by a few popular designs. Never worked with wood to this extent so I was excited to learn.
80/20 frame, bolted to 1/4 aluminum bar lined up to the rear 3rd row seat bolts.
19mm baltic birch, stained, marine carpet. I managed to struggle through not having a table saw. Rear seat folds flat to make a sleeping platform big enough for me to comfortably sleep.
feel free to ask any questions, I am sure I can go on for days about it.
10" shallow mount audiocontrol subwoofer, Iceco fridge/freezer, dometic dual burner gas stove with griddle plates. there are a few other hidden things including an air manifold and the sides (wings) have storage compartments as well.
Had a cuttingboard cnc'd out of richlight on machined aluminum rails to slide out.
Everything became a game to maximize the space and minimize the tolerances.
Man, this looks awesome! Specially since you said you have no woodworking experience!
Nice seats btw!
Just got mine to the dangerous 90% done and usable phase!
Pretty simple design!
It has room for my house battery and some of the electronics!
I have some leftover solid white oak from another project that Im going to use for the drawer fronts and I need to shave a bit from the bottom of the drawer under the fridge, since they are catching a bit with weight on it!
Nice seats btw!
Thank you! I have a new found respect for cabinet builders.
So much sawdust..
I'll be putting together a build log sometime in the near future with all of the details. Somehow ended up gutting the entire interior and re-doing everything.
" need to shave a bit from the bottom of the drawer under the fridge, since they are catching a bit with weight on it!"
This totally didn't happen to me.. I've found that UHMW Polyethylene sheets / film relieved that issue on friction points. Now its a feature.
Especially if you don't know anything about wood and didn't factor seasonal wood expansion and already stained and sealed all of the wood and don't feel like sanding it down again. :beer:
So much sawdust..
The part that Im mostly ashamed of is that my other hobby is woodworking and I do have a decent shop 😂😂
But cabinetry is still my main nemesis!
And yeah, so much sawdust
Still in the plan / build stage but here is what I will be doing for my rear storage. The tray is 26" wide by 38" deep and the sides are 2.5" tall. It will be on two legs on the right side that will bolt to the factory threaded inserts in the rear floor are. The ammo can on the left will be in a tray that will be welded to the left side 3rd row seat fender mount and will tie in to the left side of the tray to support it. Underneath the tray will be 7.5" of "out of sight" storage for things like rifles, wifes purse and anything else that needs to remain out of sight. Once the frame for the tray and ammo can are welded up, they will get powder coated black along with the tray. I will add in some tie down eyes to the tray. Personally, I am not a fan of the full drawer systems due to the added weight and though a single drawer would work with the spare tire setup, I suck at wood working and the couple of shops I have looked at to build a drawer want way too much money to do so. Also, with my setup, I can remove it completely by removing 9 bolts. I will post again when it is completed and in place.
Totally understand. I was in your exact situation. Some of these drawer systems are very expensive. When I went about designing mine I also didn't want to add a bunch of weight and wanted it to be removable. The way that the frame is designed it is removable by the t-nuts on the L brackets bolted to the 3rd row seat bars. This is the benefit of using 80/20 style extruded aluminum framing. Its lightweight and modular and in most cases you can use whatever material to cover it.
The frame is symmetrical. 42"W x 40"L x 10.5"T so if you wanted to switch what side something was in you could flip it. Once I find the CAD file I'll share the total frame design for anyone that wants the dimensions and materials needed. This way, you order the frame sections pre-cut and threaded from https://www.tnutz.com/ and all you need to do is assemble it.
Thought about designing plate that was on drawer slides that you could use the Milwaukee pack out boxes.
Full width plate is 19.5"L x 16"WYou could fit two of them length wise between the back of the seat and the tail gate. Would be fun to design.
I used this on the last set I built about decade ago. Matches pretty close for oak int in shade and texture
These outdoor carpets don't look like they'd stretch to wrap around corners, so what are people doing instead? I wouldn't want a bunch of unfinished edges.
This was the inspiration for my 8020 build
He does go over a bit on how to deal with carpeting
Just a suggestion, it is highly recommended to keep recovery gear accessible from the drivers position.
This is always the best advice. Anything needed to run your winch, straps, shackle, etc. All where it can be grabbed even if you have flopped.
@LFGdigital have you heard of OZTech? Burro Utility Slide - Milwaukee Packout™ Compatible Truck Bed Slide - https://oz-tech.com/products/burro-milwaukee-packout%E2%84%A2-compatible-truck-bed-slide
He makes custom packout mounts and other mounts for similar style boxes. Hes started making slides, I had asked him about the idea of making a slide for the 80 and he was down, I just haven't decided I really want to go that direction. Very nice guy. Met him at an event in Arkansas.
It’s nothing fancy, but it works for now. Still trying to come up with exactly what route i want To go. Any ideas with the spare tire setup? Eventually going to a rear mounted spare but it will be awhile.
