I have LED's all the way around on my cruiser (both actually). The only non-LED's are turn signals (didn't want to do a resistor, or have seizures from fast blinkers).
I tried the new 5w LED's with the "new" 84... do not fit (currently). It's close and I will eventually "adjust" them to fit i think. Just some delicate dremel work and i think it will fit. If not - no worries. Doing me no good on my garage bench!
I'm kinda a LED geek. I like the lower draw and longevity. The LED's i have on the 87 are brighter than most regular bulbs, but not super bright like the new 5w ones i want to make work.
As for heat and snow - it's a vertical surface and shouldn't block easily. Unless you get tons of snow... and easy to brush them off while clearing windows anyway. Not that i need to do that frequently w/ a whopping couple inches every other winter...
HTH!
Did you get your 5W ones from SuperbrightLEDs? If you get 'em to work, I'm curious to see comparison shots between the 5W and the incandescents.
BTW, should hopefully be able to meet up after getting back on the 10th from the cruise so I an pick up the carpet from you.
