led light upgrade LC 100
New Mexico
Good morning. Is there a good upgrade to replace my stock headlights that is reliable?
As we know they are marginal today......
Thank you.
Are they marginal? My references are the quads on a 62 and the LEDs on my 2022 Outback. My hundy’s headlights are WAY better than the 62, but a little less great than the Subie’s LED’s.
Adequate, but not worth upgrading for me. Have you checked your voltage at the back of the housing?
I did a ton of research on this after I bought my first car with factory LEDs and was blown away by the quality and crispness of the light output.
Summary: good light output is expensive and the lamp and reflector/housing should be designed for each other. It’s relatively easy to just light-bomb the road in front of you, but it’s awful for other drivers.
I’ve improved halogens by making sure there’s no resistance at the housing, and on my hundy the PO replaced one of the housings after an oopsie. So, every night I get to compare a 26 year old hazed-over headlamp to a crystal-clear new OEM one. Big difference.
I put Philips Ultinon Pro9100 (www.amazon.co.uk/dp/B0BKSSG1BF) in my aftermarket depo headlights (www.roughtrax4x4.com%2Fhlamp026-left-hand-headlamp-100-series-05-2005-on.html) and have been happy with the performance. The low beams needed clocking correctly to get the beam pattern correct, but the lamp has a design feature for that, just make sure you wind the grubs screws in, not out like I did to start with :doh:.
Caveats - I'm RHD UK, regulations may vary in your location, blah, blah, blah.
I tried LED bulbs, but went back to halogen bulbs because the quality and throw were far more superior. Only a true custom projector setup will yield you better results.
I've been looking at TEQ Custom's retrofit headlights. 100 Series Land Cruiser Custom Headlights (98-07) - https://teqcustoms.com/collections/100-series-land-cruiser-headlights/products/retrofit-headlights-100-series-lc-teq-customs. I haven't had the extra funds lying around to convince myself to pull the trigger yet.
Yikes - basically alibaba specials. I wouldn't pay $700 for those...
@NM Cruiser
I would do the following:
Get Morimoto MLED 2.0's and pair with the LW D2S Low Beam bracket for LX470, retrofit your existing headlights:
- Lexus Lx470 (Low Beam) Projector Retrofit Brackets - https://lightwerkz.net/en-ca/products/lexus-lx470-low-beam
- Morimoto MLED 2.0 Bi-LED Projectors (LHD) - https://lightwerkz.net/en-ca/products/bi-led-morimoto-m-led-2-0-lhd
I used SAVE10 code for a discount
I found this thread helpful regarding the retrofit here: HOW TO : LX470 Bi-LED projector retrofit Morimoto MLED 2.0 - https://forum.ih8mud.com/threads/how-to-lx470-bi-led-projector-retrofit-morimoto-mled-2-0.1317949/
