I have a 99 100series with 150k. The master cylinder is leaking terribly from the brake master cylinder. The inner fender is soaked as well as the frame rail with brake fluid. This look expensive. Anyone else had this issue?
I have a 2006 GXL diesel with 108000km and is leaking from the 2 bosses on the bottom of the master cylinder. This should never leak here. No parts available. I rang Toyota and they told me to go to the dealer and have a report done and sent to toyota. I did this and was told out of warranty. I appealed at the suggestion of Toyota, again no warranty. I have now lodged with NCAT. First hearing this soon.I have a 99 100series with 150k. The master cylinder is leaking terribly from the brake master cylinder. The inner fender is soaked as well as the frame rail with brake fluid. This look expensive. Anyone else had this issue?
