LC200 and KO2 Tire Pressures
NY
Anyone that has a LC200 (2019), with KO2 what are you running for psi for every day urban driving?
anyone got any lifespan data on them with the LC200?
Wouldn't it be helpful to understand what size tire we are talking about before offering suggested pressures?
How about the tire construction? For more recent KO2 tires, most are LT-Metric, but maybe the OP's KO2's were purchased earlier and might be ISO-Metric.
More info is needed from the OP - as well as anyone offering suggested pressures.
Just a thought...
It wasn't a suggestion, I just stated what I run mine at. If he wants to use that PSI based on a random dude's post on the internet that's on him.
Mine are LT285/65 R18.
Just a thought...
275/70/R18
Load E
Purchased mid 2022
275/70/R18
Load E
Purchased mid 2022
Those would be the LT-Metric LT275/70R18 tires.
The Recommended Cold* Tire Inflation Pressure (RCTIP) for those tires on your LC200 is 41psi Front/Rear.
*According to Toyota:
Tire Pressure vs. Tire Temperature
Tire temperature is dependent on “cold” tire pressure, driving distance and speed, ambient temperature and road surface temperature. As the temperature of the tire changes, air in the tire expands and contracts, changing the tire’s air pressure. The cold tire pressure for all Toyota models will vary and will need to be adjusted accordingly.
“Cold” tire pressure, as shown on the tire pressure label on our vehicles, is generally considered to be the pressure in a tire that has not been driven in the past 4 hours and has been parked outdoors.
HTH
HTH
Thank you
