LC Cargo Dimensions
Went to go see the First Edition LC this morning. All of the measurements are the same as the GX except the height of the load floor which seems to subtract 3 3/4" from the overall opening and interior height. Here are the measurements;
Enough room for a compressor.
Height to load floor (the cargo area had a rubber mat on top which should be disregarded).
Height of opening from top of load floor
Widest width of cargo area
Between wells
Cargo area depth with second row seats up.
Cargo depth with second row tumbled forward.
Cargo depth with second row seats down.
Depth with second row down
Center of load floor to ceiling.
Second row flat to ceiling.
Second row floor to ceiling (the second row floor area is lower than the cargo floor.
Height of second row floor to cargo floor (the cargo area had a rubber mat on top which should be disregarded)
Sticker
Don't shoot the messenger...
Brown Sugar Metallic??? I was under the impression there were 4 colors for the First Edition?
I have seen that color listed in a few other places and didn’t know it was a real option. Toyota still doesn’t show it on the website on any trim but I actually like how it looks from the pics above.
$5000 for AT tires - must be 42" Trepadors
I don't know what's worse, just a straight cash above MSRP or the illusion of providing some value. I think I prefer not to be lied to. But regardless, I wouldn't get it anyway.
$92,444 sounds perfectly reasonable. Ha! I wonder if that includes a tank of gas
Let’s see — which vehicle is more desirable?
(I know which one I’d choose)
exactly. those prices are insulting.
If a salesman walked up as I was reading that add-on sticker, pretty sure anything I'd say to him/her wouldn't be very kid friendly. Not sure if insulting or appaling is the correct word to describe that nonsense.
My favorite part from that list of add-ones is the $3,000 window tint which says its applied only to the rear windows - the ones that are tinted from the factory.
Where is the 12 volt battery location on LC? GX 550 and 300 series still up front. Cannot find any pictures showing it on LC250 Hybrid.
Sequoia is in the left rear quarter panel.
I believe it's in the same spot as the Sequoia.
Thanks.
Found it in the owners manual.
There is a jump start terminal up front.
Don't think this jump start terminal are rated for 500-600 amp needed for winch. Hybid engine start using the high voltage hybrid battery.
I guess installing winch become a lot more expensive. You cannot install larger battery too in the rear compartment.
There is also a conventional starter, which it uses in very cold temps and some other circumstances, so there will be a decent size wire from the battery to the engine compartment, but it's probably not big enough for winch amp draw. I wonder what the size of the stock battery is.
