I had a lot of trouble with this myself. I:so i have wheels off, shocks unbolted and was able to remove the driver side spring. The passenger side is another matter. Cant quite get the axle to drop far enough to pull the spring. Not sure which of the suspension parts to unbolt next? You tube videos i have seen are conflicting on this issue.
- removed the shocks from the bottom mount
- removed the screw holding the diff breather
- removed all 4 sway bar bolts which mount it into the diff. these were a PITA to realign
After struggling with it I later heard if you unbolt the panhard rod that will allow the diff to drop a bit further, so you might try that
