Large Case Alternator?
austin, tx
I searched and came up with nothing conclusive.
Will a large case alternator bolt up in a 95 fzj-80?
If so, how much work does it take if any at all?
Someone has got to know...
what do you mean by Large case Alt? The one in the 95 is a good 90 amps. Is this a gm or nipiondenso alt? There is at least one company that will rewind the alt for higher power at the cost of long life. Also Have you look at the tightness of the space where the Alt sits? Has some space but not much. later robbie
flintknapper
AlterStart..........a company located in Dallas, Texas has a brand new 150 amp. alternator that it sells for $250.00 it has a 2 year warranty and is a Nippendenso. I you are looking for a higher output unit this one develops 60 amps. at Idle and 150 amps. at 1600 rpm. They have a website that you can visit. I think it is: 4alterstart.com
I didn't say anything because I don't consider the one I am putting in to be large case, so just FWIW. It's a 100 amp Delco. Stock I had tested at 80 amp. Just have to make a spacer, adjusting bracket, and wire conversion.
Bill
Bill
Bill, you are awesome man, there is nothing you cannot fab or mod or invent is there? Wow what an inspiration!!!
He's a little weak on finishing up....:flipoff2:
You see, he keeps wandering aound his 80 in a circle and takes bits off faster than he puts them back on.
I figure he will be down to the frame by Chritsmas...........:rolleyes:
Thats a small case GM alternator called the CS130. The weak link on them is the colling. The high amp models were rated at 100 amps, and anything more will make more heat than its small case can disipate. Its a great little alternator but also look into the CS130D and the CS144. They are small case alternators but are designed to be higher amoerage and are found on late model GM trucks. I think the rate them at 140 amps, but there are guys out there making 200 amp replacements.
