sleeoffroad
Supporting Vendor
You continue to ask for proof on Toyota's purpose for the FPR. Someone has commented on the probability of FSM language acknowledging the same FPR being used on a 93-94 truck to compensate for poor idle (offline throttle response).
I am asking for proof that the 95-97 mass air flow sensor reads incorrectly at low idle as stated by Rick.
You have not produced anything that supports your assertion that higher pressure in the fuel rail will cause a lean condition.
You don't understand what is happening in the fuel rail.
You have not produced anything that confirms that an OBDII truck is at risk of running lean over extended periods of time without throwing a lean error code.
How many google links do you want me to post?
You have produced no proof that original sensors cannot deal properly with the new MAF. Anyone can say that is not how it came from the factory. Most of the people in this community have trucks that are different than how they came from the factory.
I did not say the sensor can not detect change or manage it. I am saying you also changed the criteria on which it chooses things.
Field testing is the ultimate test for any design. Have you heard of any blown motors due to lean operation caused by too much fuel pressure in the fuel rail???
Again, you don't understand what is happening.
Frankly, I don't trust your explanations on how things work 100%. You told me wrong on the need for castor plates with Js. My truck handles like a dream with 2 degree cc bushings.
What the hell has that do to with this discussion?
Telling me that too much pressure in the fuel rail will cause lean operation does nothing but also send flags up.
Ditto
All the while offering scenarios that lack proof like you'll blow your engine up from lean operation. The difference is that LTs design works based on real data regardless of any possible mistaken statements. The only hint of lean operation is what you are saying. No where else has this even been raised as an issue. Your only proof is that you are not satisfied with the mounds of data that prove there is no lean operation. "It could be running lean just under the radar of the ECU"![]()
If you do not understand what I am asking then I am sorry, there is very little more I can post or explain.
