Hey everyone,
I have a 1997 Landcruiser with about 270,000 miles.
Iv done alot of research and used the "search" tool for weeks but nothing has helped me out yet. After a couple of hundred bucks down the drain, im still stuck with the same issue.
The truck starts no problems, or hiccups and no check engine light, and runs perfectly smooth for a whole 5-7 seconds and then stalls out. A local mechanic took a look and said it was the relay and a couple of fuses and the fuel filter, so he went ahead and replaced those, same issue. I took the truck back because I had no longer any confidence in him. I also replaced the fuel pump thinking it wasn't getting enough fuel pressure and that didn't help. My battery is brand new and upgraded for heavier demand. I then brought a friend to check it out in my garage and we went through a couple of tests and narrowed it down to a electrical problem and discovered that when we unplugging the 3 pin connector that plugs into the alternator the truck stays running no problems or issues, but as soon as U plug it in it the truck dies out and stalls. Now we started thinking the alternator failed due to over drawn power from the huge sound system I have installed (I love my music) .
So I went ahead and spent some extra $$$ to get an upgraded high output alternator to handle the sound system and the HIDS and all the LEDS that are running throughout the truck. Now I'm still stuck in the same exact position I started in. Truck starts and runs for 5-7 seconds then dies out unless I unplug the 3 pin connector from the alternator. If anyone can please help me out or maybe in the nyc area that can help me out.
