Kzj78 spacers (1 Viewer)
London
Im planning 285x75x16 tyres and 16x8 wheels
What size wheel spacers sutable for front and rear
Thanks
I run 33x12.5x15 on 8 inch wheels and have 30mm spacers. The back is almost flush with the wheel arch and the front sticks out just a little, but the 285's are about an inch narrower, so I think they would be just right. Also I wouldnt go for less cos you'd have to grind down the studs.
So only for front 30mm. Rear no spacers ryt
Thanks
Just buy wheels with the right offset so you don't need spacers!
-25 to -40mm offset should work ok for 8" rims. Or 3.25-3.5" backspace.
I have the same size and I’m running 1in 1/4 spacers. Sometimes I get a slight rub on the control arm on full lock over bumps
This. If you’re buying new wheels then just find ones with the appropriate backspacing to run the tire size you want. No spacers is always the better option.
