Does anyone in the Spokane Washington area have
This tool avail to rent or borrow.
SPX Toyota | Tool Detail
Thanks!
Thanks!
Do you have at least an 8" if not a 12" veneer caliper?
Thanks!
I have access to up to 24" digital caliper if needed.
I have the FSM also
I would love to have a list of persons willing to rent out this SST. I will be doing a disc brake conversion in a few weeks, and was planning to make a post just like this one myself.
Brian
Wouldn't the local alignment shop do the measurements for you?
ty
A local alignment shop is often times perplexed simply by a 33" tire on a Land Cruiser.
Knuckle centering is not something that any old alignment shop is going to know a thing about.
Hit the link in post 8 and you will understand.
I suppose you could machine a shaft to project from the axle housing, rotate the orientation of the run-out indicator by 90 degrees, and you'd have a good DIY tool, like the purple in the diagram. But that's not what the tool described in the TT does.
I need to re-read the TT article - hard to read on the screen but I see what your getting at. Do you mean 90 or should that read 180 degrees?
Also anyone know what accuracy is being sought? I know as good as possiable but everything has a tolerance, suppose I should check on the shim range...
