Knuckle centering tool-Is it necessary?
Batesville, Arkansas
Here's what I've got. 1967 40 series. Taking out the ball and claw front axle and swapping in a 1978ish axle housing and mini truck inners, birfs, knuckles, and disc brakes. Everything has been pieced together so obviously there was never an option to properly mark the shim packs and put things back together the way they came apart. So do I need to try to beg, borrow, or steal the uber rare centering tool or is it really a necessary step in the assembly? I have Marlin's heavy duty inner axle seals and I've read somewhere that when using this seal, things don't have to be centered perfectly.
Thanks in advance for any input.
I've got one to loan.
I drink Coors Light
I have the marlin seals and I didn't use a tool. It doesn't leak. I think the difference is that marlins use a clip instead of a spring which helps them keep better form even if not centered. But it would probably help the seal last longer if it wasn't a little stretched to one side still I think.
When I rebuilt the axle in my '78 40 using '79+ knuckles I didn't use the tool. I had no idea how to get a hold of one back then. That was at least a decade before Marlin's seals were available so I just set the preload with a liltle spring scale and then divided the shims evenly top and bottom. I have a little seepage on one side but still haven't bothered to change the seal. With locking hubs most of the time the inner axle isn't turning anyway. Maybe I just got lucky.
