Mighty Mouse
I've not been able to drive my 94 Land Cruiser for over three months now. Like so many other posts on here where it appears chasing an electrical issue nothing has worked.
In short, the cruiser 1FZ-FE engine, will start fine, idle fine, but as soon as you start to drive, it stumbles and won't drive forward, unless I can get RPM over 3000.
Every posible part, and the list is long, has been replaced.
When I was trying to replace the ECT sensor, both the plug for the ECT and Knock Sensor broke off as they were dry and brittle. Before this, I had no CEL codes at all. just wouldn't drive.
I have replaced both the ECT and the $250 OEM knock sensor because it started throwing code 52 after I got my grubby hands under the intake manifold and broke those connectors.
this is already too long, currently I'm still working on the code 52 and today I tried a continuity test between knock sensor plug, and ECU plug. No beeps so no continuity.
I disconnected the WHITE plug as it had the white wire at pin 4 that I was looking for, and on the other side of the plug, that turned into a Red with silver trace pin. no continuity. even on every pin in that ECU plug.
Was that the right plug?
If not: what plug should I be probing?
If so: then what's next, tracing the entire loom and how to do that? What's my next move?
After three months of almost daily work, I'm exhausted and frustrated beyond capacity. I can't sell the dang thing because it isn't running. My options seem very limited.
Just looking for ideas or suggestions for now. Thanks
Mike
Wyoming
1994 LC80 1FZ-FE engine
Mike
Wyoming
