Kickdown cable not retracting (3 Viewers)
Minnesota
Is there any way to get the cable to retract to adjust it properly or does this mean that I need a new cable...Its adjustment is maxed out but the ferrule/cylinder on the wire should sit much closer to the orange stopper. I'm wondering if I replace the detent spring sub assembly in the throttle body (part 35409-60010) if that would fix it not retracting or if I need a full throttle body rebuild with a new cable? The cable did seem just fine a couple months ago when I adjusted it (probably way too loose because I followed FSM spec)
This is a 1992 80 series
