Keyfob only works when pressed to windshield (1 Viewer)
Texas
Hi!
I have a 2002 LX470 and just got new keys programed after they were lost by the prior owner. The keys are cut and successfully programmed. However even with fresh batteries I need to hold the key up to the windshield to get it to work, like touching the glass. Then it will lock and unlock the car. My dome lights work just fine.
Any ideas what might be causing this or areas to trouble shoot?
Thanks!
I've got the same issue.. Havent tried anything yet, but hope its as simple as changing the FOB battery
I swapped batteries and no luck. I found this old thread using GPT
Does anyone know how to get to this control unit? I cannot find any decent photos on what I need to do to find it and remove it. Thoughts?
Thanks for sharing that link.. I'll definitely be extending the antenna or the box itself with a pigtail.
I havent looked myself yet, but as he says: "The receiver box ("Receiver, Door Control", P/N 89741-60060 for my '98 LC) is buried in the dash behind the power mirror & vent window switches, an area surrounded by a lot of metal and isn't the best for radio reception"
Take off as much trim as you can, get upside down in the wheel well, and hopefully you can see it.
It would be awesome to build an extension thats more plug and play then adding an antenna. I was trying to determine what I might have to buy to do that and connect it myself.
That thread includes two metra harnesses where you can get the male and female connectors needed. But, they'd need to be repinned with longer wires to combine them together. @ruifrsilva has a good post here with some part numbers from mouser for repinning these connectors. Perhaps Mouser even sells the male and female connectors as well so we don't have to buy the Metra harnesses just to take them apart. But, I'm not very familiar with all of this stuff and have no idea how to find the right connectors or male pins to use here.
