Just wanderin??? Pinnacle shackles? (1 Viewer)
My new to me 60 has some pretty ugly road manners..has pinnacle shackles with some lift 2"? front and rear. Axle has been completely rebuilt, so I don't suspect that, has 16 inch rims/tires. Bad on center feel, do I need shims, or just pull this junk off and go back to stock? If shims, where to buy?
www.southwest4x4.com sells shims in varying degrees of correction, as well as different widths- and from my dealings with them they have been prompt and helpful.
Castor angle is probobly off... shims will correct that. They are also cheap, so that if shims don't correct it, you're not out much $$
Caster shims should solve the problem, but you may also want to address the 18-24 year old TREs and steering joints. They can cause funny handling as well. I think Kurt at CruiserOutfitters sells a complete kit, or check SOR.
Hodag
