@Chad717, did you do the paperclip test to make sure the secondary diaghragm is opening. I don’t see that valve going bad from just removing it and putting it back on for a rebuild. Gas in middle of sight glass..linkages not hanging up..secondary butterfly valves closed in bore when not being pushed open..linkage adjusted properly to start pushing secondary linkage at the right time..cooling fan kicking on..
Seems there are more things to investigate before modifying the valve.
@LAMBCRUSHER I was nodding up and down with you till the last sentence, carbs were my #1 spot in the favorites list till recently, now #2 right behind the VB and A440
I was simply summing up their actual function. carbs suck. it's what they do...
