Just making sure on Mini Hubs, Spindles
Hiding
Hey Guys, I searched and read, but need some reassurance here.
I have a 77 FJ 40 Front axle. It has the 77 Spindles.
I have mini Truck birfs. and the asian Lock outs.
I am planning on rebuilding the front axle. new gaskets etc. Grinding the opening up a bit, to fit the mini birfs, and then using the asian lock outs. The only think that is not FJ 40 will be the lock out hubs and birfs.
Question 1. Will the asian / mini lock out work with the 77 spindle?
Thanks, My ace hardware "smurf blue" will be in today.
nuclearlemon
not an addict
Moderator
meh-ico, colorado
yes, they should, but you really should use the mini knuckle housings and arms/bottom plates. the wider stud pattern is stronger.
Hiding
[QUOTE use the mini knuckle housings and arms/bottom plates. the wider stud pattern is stronger.[/QUOTE]
Other Mini parts are in a state to the north.
Im not worried at this point about breakage. I dont even have seats in the truck.
