- Joined
- Apr 17, 2009
- Threads
- 17
- Messages
- 2,669
- Thread starter
- #261
Question(s)-
In general, where should the rear shock brackets be mounted?
I'm assuming that in order to maximize the articulation you'd want the upper and lower brackets to be as far apart as possible so that the longest shock could be used...like on the side of the axle housing and on the frame cross member. I guess that's the way it is from the factory, and that's the way the lower mount is on my 80. That mount has taken a beating as well! It seems like that moving that mount to the top of the axle would be better in terms of protection, but would the loss of additional travel outweigh that?
Also, a lot (most) of the trucks I've seen have the rear shocks angled up towards the center of the cross member. Is this just so you can get a particular shock under the truck (i.e. they are too long to run in a true vertical position)? I can understand the geometry in terms of the angle and net travel, but is there a max or desired angle when installing them this way?
Kinda at a loss here...
