Can you guys list the pros and cons of the J's vs. the OME heavies. I have read a ton here, and on Slee's faq. Sounds like with the J's you gain another 1.5 inches for a total of 3.5-4 inches of lift. One question is can the caster be corrected back to normal--also what else is needed besides extended brake lines, and diff breathers? I know many of you run the OME heavy--what is the reason? With all the reading it sounds like the OME heavy is an easy plug and play install..... Just thought I would get your guys thoughts berfore I make this decision---if it helps I will be buying from Sr. Slee
