J-Robs truck saga (2 Viewers)
Jrob, any updates? It has been a couple of days. Should already have the axles and links mounted by now. You guys slacking off?????
They worked last night (I had other obligations) so I'm sure JT will update soon.
No pictures, but here are a few updates:
Jrob and Bodean created templates for frame reinforcement plates for the inner and outer frame rails up front, and cut them out of 3/16" material. The smaller inner plates were drilled for additional plug welds, and the outer plates were drilled with much larger dimple die style holes. Jrob has welded in the inner plates and begun welding up the outer plates.
We cut all the brackets off the rear 80 housing and started grinding away at what was left behind. Not quite done yet...a task equally miserable, I'd say, to assembling a set of beadlocks.
Last night was spent double/triple checking a lot of the measurements and tweaking the calculators. It should be dialed in well enough now to start tacking in brackets for mock up.
Hopefully the new housing will show up soon. If it doesn't, there's still a lot that can be done - rear axle needs to be pulled out, rear spring and shackle hangers need to be cut off, rear frame needs to be cleaned up and prepped for reinforcements, both of the 40 axles need to be torn down so the thirds can been removed in preparation for the transplant, etc.
I'll get some pictures of the Jrob FAB tonight.
Tip of the day.
When you start burning all this stuff in on the axle housings take it super slow.
Most people that do brackets on fabricated housings have bars that keep it straight or jigs.
It can be done at home but they are much more likely to wrap and leak as a result versus a heavy ass 60 or 14 bolt
Dusty said we could ride out and get his rig to keep for reference. Just sayin. I'm up for a road trip!
If we can keep the tires aired up I'm sure he wouldn't mind. We'd need to get all the articulation numbers anyway...
Good plan.
That's a bad SOB right there!
Talk softly and carry a purple 40.
The Great Gaping Grape Ape!
Jrob welded some more on the frame plates...doing a little at the time.
Finished cleaning up the rear axle.
Ripped the original rear axle out, tore it down, and pulled the diff.
Pulled all the wiring and hoses back to get the rear frame ready for the plasma, grinder, and welder.
Any time you wanna come help us you can there Fergie!
