Really impressive build.
Do you think it makes sense to put some type of drain under the fridge to divert water or moisture outside?
Makes sense. I don't see much water getting in there unless you are towing the trailer in a rain storm. Have you considered making a cover for the vent while you are towing?
Also, I don't recall if you were going to install a CO2 detector/alarm. Have you done any research on which one is the best?
too I did a little research on my own question re: carbon monoxide detectors.
Cliff Notes on attached links:
1. You should have either a carbon monoxide detector or combo CM/smoke detector that is less than five years old.
2. You should also have a propane gas detector. These get mounted close to the floor.
3. You should have a fire extinguisher.
They may be overkill but the small space of a camper combined with deadly gases seems to warrant $100? spent on an early warning system with the latest technology.
Here are the links:
Kidde seemed to get good reviews. Don't know about the propane detector.
Best Carbon Monoxide Detector - Carbon Monoxide Detector Reviews - Carbon Monoxide Alarm - Nighthawk
RV Lifestyle - RV Tips
RV Alarm & Safety Detection Equipment That You NEED To Have Onboard At All Times - The Fun Times Guide to RV Road Trips
Amazon.com: Safety Siren Combustible Gas Detector for Natural Gas (Methane) and Propane: Home Improvement
where did you pick up that popup?
i have looked up rebuildables, and the only person's i know in body work are in SD.
what are you going to do with the rest of that one you have?
