Is This the End for My AHC Pump?
Little Rock, Arkansas
Good evening friendly AHC wizards,
I think it's time for a new AHC pump (motor) but I'm still finding my way around the system and wanted some confirmation before pulling the trigger. Here's the situation:
Background-My wife and I replaced all 4 AHC "shocks" with new OEM ones (and some other things, post to come once we are back to normal). Before this our AHC was completely functional with about 8 gradations of movement between high and low and good pressures (can provide specifics if helpful). I flushed the system about 8 months ago with no complications or concerns at the time or since.
Problem-now that we have everything hooked back up the truck is stuck in "neutral" even though its actually riding close to if not below what normally measures as low height. It won't cycle up or down.
When doing the short in the diagnostic port the motor runs and makes an *awful* screeching/grinding noise. It runs continuously, but it's only able to lift the vehicle up to something approximating neutral (the interior display always reads neutral) before it loses pressure and falls back down again.
Codes:
-C1761 AHC ECU Malfunction (this might be old. The off light has been blinking since we got it but not once has it affected functionality).
-C1762 Abnormal Oil Pressure for Pump
Data- front and rear pressures are reading 0.0, accumulator reading 0.3. This actually was the case before in neutral position sometimes, so I don't know how trustworthy these numbers are, but the pressure is definitely low (see next section).
Remedies attempted:
1) draining all 5 points- pressures were much lower than previously, even after running motor. No noticeable vehicle drop on draining.
2) manual operation of motor via short method- hoped maybe there was air trapped and this/bleeding the accumulator would fix/improve things. No such luck.
Thank you very much for all help in advance!
Air in system? - completely functional before, bad pressure and awful sound now points to this. The pump hates air and hates you after running on air.
So yours was the same situation and this fixed it?
Simmilar, I blead my system but botched it on the height accumulator when the house fell off and it ran dry letting air into the system. Took a lot of bleeding but eventually came around. As mentioned above the system is very sensitive to even a little air.
If you’re going to take pump off I suggest taking it apart and cleaning it up. It’s not difficult and could be the solution.
Codes:
Remedies attempted:
I agree with the suggestions in earlier posts in this thread. In particular:
Clear all Diagnostic Trouble Codes (DTC’s) so that you know you are not dealing with old information. DTC’s will re-establish themselves if faults still exist.
Be aware that air in system can be hard to eliminate and may require multiple efforts. The thread leading up to Post #243 by @aharlan001 shows how frustrating this can be and the persistence which may be required:
AHC Inop after fluid change 2007 lx C1751 and C1762 - https://forum.ih8mud.com/threads/ahc-inop-after-fluid-change-2007-lx-c1751-and-c1762.1233088/page-13#post-13517321
When confident that air in the system is not a problem and if you are inclined to repair or replace the AHC Pump, then as mentioned by @BullElk it is not a big job.
To understand the AHC Pump, it is worth looking at the description and diagrams in
LC100 Workshop Manual - https://lc100e.github.io/
Look for the index tabs starting at top left hand side of the opening page and choose these tabs in order to reach the General Description document:
New Car Features > CHASSIS > Suspension > Active Height Control Suspension.
Then suggest also review these well-illustrated posts:
Post #67 by @BullElk at AHC pump out? - https://forum.ih8mud.com/threads/ahc-pump-out.1226629/page-4#post-13401098 for pictures of a clogged pump.
Posts #69 and #70 by @IndroCruise at AHC pump out? - https://forum.ih8mud.com/threads/ahc-pump-out.1226629/page-4#post-13407297 and onwards shows pictures of AHC Pump disassembly and also show the tiny filters (strainers) within the Pump. Pump disassembly, cleanup of the pump and backwashing the filters (strainers) are all straightforward and is made easy by removing the motor/pump/tank assembly from the vehicle. Even if the decision is to replace the pump, disassembly of the existing pump is still recommended. It is better to know how much 'gloop' is in the system before installing a new pump and risking another blockage.
Toyota/Lexus and the various resellers do not offer internal pump parts for sale and instead offer the AHC pump unit in various combinations:
48910-60012 whole pump and motor assembly including pressure sensor, temperature sensor and AHC tank (Price example: USD1,204.04 on Partsouq)
48901-60010 pump only sub-assembly (Price example: USD160.79 on Partsouq)
Obviously repair/replacement of the AHC Pump involves first depressurising the system to allow the Pump to be removed. Reinstallation and reconnection requires repressurising the system, possibly using the “Active Test” to get the Pump running, and certainly involving the usual persistence and all-points bleed to clear air from the system.
The above notes assume that the AHC Pump motor is in good condition. It would make good sense to check the AHC Pump Motor by applying 12 volts to its power supply and briefly running to check no strange noises from bearings or brushes, or, remove end-cover from the motor and inspect. Probably it is OK -- pump motor problems are rarely reported. Some pics of the motor can be seen at Post #11 at AHC help ... yeah another one. - https://forum.ih8mud.com/threads/ahc-help-yeah-another-one.985078/#post-10980693.
Notes on pump removal and reinstallation can be found in the "Repair Manual" section of the FSM -- which was the source of the diagrams below:
Hey @aharlan001 how do you chase the air out? What are the steps to bleeding air out of the system.
I have air in the system. I can hair the pump making that same horrible squeeching sound.
It's been ages since I dealt with this but there are valves that you open on the assembly that the globes attach to and maybe a 5th elsewhere. The info is somewhere on the site. Use a hose on the nipple so air does not get in. (This is how air got in my system, no hose and I couldn't get the bleeder closed when it ran dry). I still get a screatch every once in a great while when raising? The vehicle but the system works fine otherwise going on 3 years now. I had to recycle several gallons through the system to sort the issue.
Hey All - Long Story short before I start posting on a new thread, I'll reply here and see if I can get any answers. I'm new to the forum, but have been lurking for a few months using it to solve small problems on my 2003 LX470.
Now I've hit the big one. AHC issues after replacing rear springs (King KTR79s) Globes and a very long overdue flush. The system worked for a bit but I've been circling the bowl for a week now, getting worse every day.
Current question without going further into all the details that would require a new thread - I'm following the FSM for DTC1762. Pump works (sounds great after a pull apart and strainer clean). Active test is a no-go because ECU is persistent on throwing DTC1762 every time it's cleared. Just tested the Fluid Pressure Sensor. FSM says input of 4.5V on pins 1 and 3 will return output of 4.5V on pins 1 and 2. I'm getting about 4V, losing 0.5V.
Question is, does anyone know if this indicates failure? The FSM doesn't give a voltage range acceptable, but seems to indicate that voltage in should equal voltage out. Is it possible that I got fluid in the FPS during assembly and wrecked it? Can I remove FPS without draining the reservoir?
I know a lot of these AHC threads are old, so hopefully one of you with experience will see this and be able to weigh in?
TIA.
TIA.
Edit - additional information.
FSM vol 2 has a different test for the Fluid Pressure Sensor, so I've completed that, as best I can. It asks to read voltage off the back of the FPS connector while in "N" with vehicle running. I cannot get the truck into N (it's sitting on the bump stops with lots of fluid in the reservoir currently, and throws DTC1762 instantly everytime I clear it) so I checked voltage in Low, which reads 0.49V. Acceptable range according to FSM is 1.48-1.85V. But this is the value for "N", so I cannot definitively say that the FPS has gone bad until I know what the voltage ought to read in "L". I'm wondering if there might be someone willing to check that voltage on their own known good LX470 for me?
Hoping it's ok if I tag some of the AHC gurus? @IndroCruise or @suprarx7nut ?
Hold tight all - don't want to make anyone do additional work - I'm currently reading this thread and will report back.
See also response at your other thread:
