My FJ40 is experiencing a strange battery charging condition. I noticed it when my Ahmmeter in the dash cluster was acting strangely. It was reading about midway, then a little lower than the middle tick mark, then to the regular position about 1/4 in past the middle tick mark, then it would jump to almost a full meter on occasion.
I verified this condition by checking the voltage of the battery while the engine was running. The voltage jumps between 12.8v and 13.5v, and once up to 14.1v.
I checked all the connections and grounds. They seem to be in working order and installed tightly and properly. My only guess is my voltage regulator. I turned the motor off and checked the battery. It's at 12.7 volts, so it would seem it's being charged, just in an odd fashion.
Anybody have any ideas?
EDIT: I also check to make sure the alternator and belt was tightened properly. They are.
2nd EDIT: Now my motor won't turn over. The battery is good, and the engine fuse is also good. ¯\_(ツ)_/¯
