Metric TLC Leather Install Begins
Ok, so anyone who has been in any of the TLC forums knows Shane at Metric TLC and that he makes some killer Leather Seat covers to replace any 40, 60 and 80 seats as well as LX450, and maybe some 100 series (not sure on those). When I got my 98 the leather was decent for 169k miles but the drivers seat was pretty worn and I decided I wanted to put some new covers in. Well I took a shot in the dark and PM'd Shane to see if he had ever done and 3rd Gen 4Runners and after a few email exchanges and some pictures, we struck the deal.
***Disclaimer****
Per Shane to help avoid confusion:
Metric TLC does not make 96-02 4Runner seat leathers as a regular catalog item and it just happened that he had done a set for a friend and had the "sport" seat patterns on file. Anyone who is interested in some of these covers will need to confirm with him that the pattern that he has will work with your seats.
***End********
So that said, after a couple of weeks I got the big box at my office. I opted for both rows in a darker brown leather with tan stitching. I sent him my console lid and he even recovered that for me to match. See previous picture.
So I finally found the time to start working on the seats. I went with the rears to start with because they seemed to be a good point to cut my teeth on this upholstery business.
The bottoms come out with two bolts at the hinge. To remove the backs you need to remove the carpet cover from the back, a screw driver or a panel removal tool will work to pop the push pins out of the frame. Once the back is exposed you just remove 2 bolts and the back comes right out.
I started with the bottoms, there is a plastic edging that hold the cover onto the metal seat pan. Then 4 hog rings need to be removed to separate the cover from the seat foam.
Here, 2 on each side
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3256_zps608ef0b7.jpg
Then the cover comes off.
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3257_zps520d4468.jpg
New bottom
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3259_zps46bed257.jpg
Need to remove and reuse the little metal rods that come from the OE cover
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3261_zps9ef9400b.jpg
The material that Shane uses for the sleeves is a little heavier than the OE material.
Then 4 New hog rings to hold the bottom on
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3262_zps8f8334d5.jpg
Shane provides a bag of new Hog Rings and a pair of pliers to install them with his kits, talk about a one-stop-shop.
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3265_zps7af8e4d0.jpg
Then you just have to fight the plastic edging back onto the metal pan and Ta-Da
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3267_zps71dbb456.jpg
Bottom done and ready to go back in.
Now to start the back
Started like this
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3270_zps833dec25.jpg
There are about 14 hog rings holding the cover onto the frame
Then the headrest and latch pull handle trim pieces have to come out so you can get to the one pair of hog rings holding the cover to the cushion
On these there isn't a metal rod, but a plastic one that is made into the material
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3271_zpsd122502e.jpg
Using the supplied utility knife (yep came with that too) I cut the plastic rod off
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3272_zpsa86036dc.jpg
Now you are ready to prep the new cover
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3273_zpsa16dddec.jpg
Note the black edging and the precut holes for the push pins to go back thru. On these covers Shane uses a heavy plastic edging that you use to hog ring the edges of the cover back onto the frame, however, there is a small hole in the edging and if you cut one end off of the original metal rod then you can actually slide the metal rod back into the plastic to give it some added rigidity.
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3268_zps3b1d1256.jpg
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3269_zpsf620cd08.jpg
I did one completely before I realized this and I went back and fixed it. The plastic trim bows considerably and the addition of the rod seems to keep more even tension on the whole length of the fabric.
After fighting with those 14 hog rings again you end up with this
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3274_zps1dd81aa8.jpg
Cut the holes for the headrests and BAM!
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3275_zps88fb7783.jpg
Then four bolts and you are back in business.
I actually did the drivers side last night so below are a few pictures of it next to the original passenger side seat.
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3252_zps74289db8.jpg
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3249_zps887b5d15.jpg
http://i84.photobucket.com/albums/k8/mrtucker80/IMG_3253_zps3f365aab.jpg
The flash gives it a slightly yellowish tint, but the brown actually matches the dark brown trim very closely in the natural light.
I did the passenger side tonight and I will get a couple pictures of the completed pair tomorrow.
The texture and quality of the new leather is fantastic. The old leather is slick and worn, and the new leather has a very soft feel.
Aside from my hands and fingers being very sore, I am very happy with the end result. Shane makes a top quality product and if any of you 3rd Gen guys are looking for some new leathers, then he could be your guy. If you are looking for a good quality replacement cover, then look him up.
I still have to do the fronts and will document that in a later post.
