So about how long is the "bed?" I've always wanted to see one of these keep open wheel wells for full stuff with the giant rubber like how they are on short course/baja trucks...
Just stick a 'pinched' FJ45-esk body on it. Then 40s will clear lock to lock at full bump no problem if you get the backspacing right....
P.S. Don't do that, it's a ton of work!
If you have a second. Could you measure the distance on the front axle from the bumpstop pad to the metal lip on the bumpstop cup? Thank you. I am just just looking for a reference measurement of what 'stock' is.
expanded metal all the way across after you narrow it with some LED lights hidden behind it. would look good, be cheap and offer great protection.
Mine looks to be 1 3/4"
Do you have a pictures? It's only 1.75" from the metal bump pad to the metal lip on the bumpstop cup? As in you only have 1.75" uptravel before the axle would stop on metal?
I measured the bottom of the rubber bump located inside of the coilspring to the metal contact pad. You want metal (above the rubber) to metal to metal measurement?
As long as I know what the measurement was that works, thank you. I think measuring from metal to metal is more accurate in the end. The rubber parts tend to wear over time and whatnot. This is on a stock 80-series? No extra front weight like a bumper or winch?
That is interesting that is at some reduced weight. If I remember right the stock bumpstop allows about 2.5" of uptravel if you where to compress it all the way into the metal cup. That would make for about 4.25" uptravel metal to metal. I don't know if the front suspension could ever get that compressed with the factory bumpstop in place, but the suspension will compress that far without anything else hitting.
I pulled the bumpstops on mine and have been building the chassis out at full metal to metal bump in an effort to make sure everything clears. Eventually, I may replace the rubber factory bumpstops with some kind of air bump....
So basically you are saying with coils pulled out and this thing resting on the metal to metal "bumpstop" everything would still clear? That is crazy!! Would ther be any other factory built suspension that would allow that!?
I'm guessing my factory springs a sagging not sure but from the front end I currently have removed the following parts and pcs:
Abs gone
Cruise control gone
Both inner fenders gone and some of the core support.
Both fenders trimmed
All the lights
Grill bumper
For weight loss on the front I guess having the pass seat out and sun roof out counts to. I have no idea how much weight that equates to but it still sits low in the front
