wanting to slip an internal rollcage into my hunting 70. Anyone got any pics of their installs, to help me along with my ideas?
cheers
cheers
some other nuggets of information. those little boxes mounted immediately behind the bullbars are proximity sensors so in the event of a smoke filled tunnel, the troopie can still be driven without crashing into the tunnel walls. Also as troopie is for use in coal mines it has an air started starter motor (big blue tank on front)and wet scrubber for the exhaust and all the electrics are totally sealed to stop sparks. The red stubby thing on the front bar is another safety feature so it stops the engine if that sensor enters a gaseous zone. That red button on th front is either a kill switch for the engine or fire suppressent switch for the engine bay.
Hello,
External rollcages are bolted to the chassis, right? How do they compare to internal ones?
JuanJ
Im impartial to which type of rollcage to have, as im not intending to drive extreme enough to roll.
i had a troopie which i suspect previously had an external rollcage bolted to the underside of the chasis judging by the rust marks. I think it had rolled because theres battery acid damage on the underside of the hood/bonnet and there are 4 identical small curved dents on the 4 corners of the roof.
An EXternal rollcage -if the correct type- will protect passengers and the body work. An INternal rollcage will protect passengers.
An EX will probably be heavier, introduce more wind resistance but if bolted/clamped to the chasis there shouldnt be any holes drilled into the bodywork and like my troopie it can be swapped from vehicle to vehicle. Also the EX allows for lots of hands to help you when your bogged down.
I reckons an IN cage is nicer to look at on a car from outside, no wind resistance, nothing for you vehicle to snag on, but it compromises space inside, bodypanels protection, to a lesser extent stability of bodywork from drilling holes.
Mine is a slightly modded factory cage.
