Hey guys,
I will be cutting out some wheel spacers for my truck in the next week or 2 and was wanting to see if I should go ahead and order some extra material to cut some extras. Please only state that you want a set if you are actually willing to buy a set. I don't want to cut out 10 sets and then be stuck with 8 for 2 years.
The spacers I will be cutting are made of .375" 6061-T6 Al (typical Al alloy). They will slip over the stud and the hub with minimal slop. They will be precision cut using a waterjet. Balance will not be an issue. They will be $125 shipped to your door per set. These type spacers work with alloy and steel wheels. They are beneficial in the fact that when running larger tires/ remote shocks they will minimize or eliminate rubbing during articulation without adjusting your turn stops. when compared to a 1"-1.5"spacer, you are not using separate studs to bolt your wheel on, they will not push your wheel out of your wheel well and "eat" your fender.
Please let me know if you have any questions or if what I said was too vague. Let me know if you are interested in getting your hands on a set.
