I noticed a dramtic decrease in the temps (3b) after my top mount intercooler install, but still struggled with temps towing my trailer (5000lbs) up similar grades like yours in summer. I had a 3 core brass full mechanical fan runing egts around 1200f max. I would look into making sure all of the foam sealing around the rad is in place to prevent it from sucking hot engine air rather than cool outside air. It is common for the foam to disintigrate. Make sure your fan shroud is not leaking that way as well. I was going to go to a mini truck fan but it would need a bit of work to clear the rad hoses as it runs closer to the block than the stock fan. Maybe an 80 series fan would fit better. I never tried it though. Before you add an extra radiator I would look into a oil cooler. I would only do a second rad as a weird last resort. Upping your boost to net lower egts will help with rad temps as you will shed less heat into the exhaust runner. I would think an intercooler would be better though. Remember that front mount intercoolers, although they are great at cooling the charge air, shed that heat directly in front of your rad, making your rad less effeceint just like your ac does. I use to get the very real sence my engine was super heat soaking before my top mount intercooler. My egts after long hauls would climb effortlessly it seemed. After poping my hood I was scared to touch anything int the engine bay it was so hot. Engine ran much cooler later, although I was still pushing it hard and the temps would slowly climb.
Here are a few suggestions I would do in your shoes in order of ease and cheapness fomr a guy who has blattled heat for a long time.
Full mechanical fan (weld.. wire.. zap strap what ever way)
Increase boost a couple lbs with no extra fuel, or decrease fuel a tad (prefered)
check thermostat that it fully opens (boil in a pot of water)
Wrap headers and turbo exhaust housing.
Reroute air box to only draw cold air and no engine bay air
hood louvers
New water pump
Fit a larger fan (either a mini truck or you could try a 80 sereis as they are larger too)
oil cooler
Intercooler
Dont underestimate the effect of louvers and ducting and stuff. I tried an experiment with my 80 as Im getting ready for a vacation drive to Oregon with my trailer. The 1fzfe has a nasty habbit of melting engine harness wires. So last week I took off the rock guard from under the rad, hoping to help the rad breath easier, as well as proped up the hood with a few washers to act as a cowl to draw in cold air off of the windshield cooling exactly where the wires seem to usually melt... well that actually had the net effect of drawing in cold air yes, but it inhibited the rad from drawing in as much air as well. The trucks temp slowly started to climb to where it would have overheated just driving down the freeway unloaded where as I towed my trailer fine the week before with no temp issues at all with everything in place stock.
Do some reading on cooling issues, most dont arise from too small of a rad. Its usually a combination of other things. Keep in mind what Dougal said too. IDI engines shed alot of heat naturally. I hate to say it, but in my opinion your engine probably sheds the most heat per Hp of any engine Toyota mada. I am sure though there is a solution out there for you. Try the simple things first before you make big changes.
g
hood louvers
New water pump
oil cooler
Intercooler
g
