Just re-did mine, and had re-used the OEM "pad support plates" for several brake changes, but couldn't get rid of the squeal. Smart shopper OEM price to replaces these little stamped parts is three bucks and change apiece, so I went with NAPA kit UP91446A, which had all 8 plates, plus rubber boots for the slide pins for ten bucks (ish). NAPA description is "NAPA Ultra Premium Rear Disc Brake Hardware Kit". Save you a few dollars... I had to go OEM for the shims (04946-60031) for my 2000.Sorry to resurrect an old thread here however I found a solution to properly oriented wear clips making noise. I found that the lower outer clip had worked it's way in toward the rotor and I was able to grab it with a needle nose vice grips and pull it outboard away from the rotor. Noise gone! I guess if it happens again I'll have to take it apart and figure out how it is slipping out of place and likely replace. Anyway hope that helps someone. Been driving me nuts for the last few days after new pads and rotors.
for the front pads, should the retainer catch both of the shims and pad or only catch the inner shim and pad then the outer shim is isolated (which with clip for piston )?Here a shot of 07LC w/64K and no record of rear brake work being done. You can see the anti shim plate on outside is the full (uncut). It has undercut shim with horseshoe back on back/inner against piston. It also has wear indicator on inner top. You can also see correct orientation of clips (Rear disc brake support plate)
View attachment 1776123 View attachment 1776124
Orientation of clips (support plates) is same on rear
I'm not sure what you're asking. But if you go back to OP (post #1). Look at FSM pictures posted there fpr front back pads & shims. That's how they go!for the front pads, should the retainer catch both of the shims and pad or only catch the inner shim and pad then the outer shim is isolated (which with clip for piston )?
Thanks. I mean is this order/position of assembly looks about right?I'm not sure what you're asking. But if you go back to OP (post #1). Look at FSM pictures posted there fpr front back pads & shims. That's how they go!
But I find the inner brake pads are the thinnest 8 out of 10 time. The times, outer pad wearing faster (2 out of 10), is when the retainer clips or shims or pins have issues like sticking.
It may be wear indicator is affecting drag of inner pad, hanging up inner pads. IDK. But because I see so often inner pads wear faster. I've switched to wear indicator on inside. This puts shim in reverse of intuitive orientation for shape of rubber backing.
If I get reports back of pad wear more on wear indicate side, regardless of in or out. Then I'll go back to wear indicate out. But for now I'm place shim cut for wear indicator inside and wear indicate inside.
If anyone has put wear indicator out, and is now replacing pads. Speak up! Which pads have worn the most?
