I'm in process of a tcase rebuild - looking for some parts
san pancho, ca
A buddy is taking the time to show me how to rebuild my 3spd Tcase, and it looks like I could use replacements for the following items:
Both selector forks
One 10spline input gear (primary drive gear)
Anyone have these items collecting dust?
Here's a little technique to removing the output shaft.
Insert bar and utilize internal housing step to brace gear and hit w/plastic mallet :D
I was shocked when I realized what's involved to operate our front DS :O
2whl drive:
4whl drive:
Hard to believe it's all about this sliding sleeve.
my new beverage holder :D
SPARE housing (74?)
This project is just another example of how our cruiser community ROCKS!!
Rodney, I really appreciate you taking the time to show me how to do this right.
It is appreciated :D
manny
Just talked to Georg...he's an hour away from Katemcy.
If he makes it back, he has the parts I need.
Thanks G :beer:
Great thing that you are documenting this...it is always a learning experience here in Mud
BTW. I want a freaking Newcastle now............... Damn work!!!!!!!!!!!!
Prod Date Code
Hey Jim, how do you desipher the date code? I have a case that has- top line 91231, bottom line- 2 J 7. I " think " its a '72 case, as it came behind a floor shift 3 spd tranny, but is there a " formula " the average joe can go by? Thanks, Al
Just about finished my tcase late last night (pics will follow)...
I found that I was missing both the front output, and input seals :(
Also, we tried to salvage the front 2/4whl selector fork...but it wasn't meant to be :(
Does anyone have a descent spare?
thanks,
manny
ok, where did I leave off...
Start w/some clean tcase parts ala TopLoader
Thanks again for taking care of me Mark :beer:
and gaskets, bearings
Thanks again Georg for the hi/low fork and gear I needed :beer:
Beverage of choice...tonight it's Marzen
One item that is not always replaced is the button...kinda like a freeze plug
You might get away with reusing your old thrust washers, but the roller bearings definitely need to be replaced
We began the evening w/some grease and bearings and don't forget the spacer
Remember that the thrust washers have a key-way
Good lighting and patience will aid in aligning the gear/thrust washers/shims in case for installation of large shaft
(I remember there are some o-rings you also have to deal with)
Replace output shaft roller bearing
We did not have to press on any of the brass bushings, as everything was in good shape.
But if you do, remember to align the oil passages
Place the gear and selector sleeve inside of case before installing output shaft
Attach gear/washer and bearing and insert into case
Current state of installed output shaft
The rear shaft will also get a gearing and washer
Brace the case before installing the rear bearing race
The race has a stop in the case...which will position it below the case.
Make sure you the race is fully seated
Now your ready for a spacer and the speedo gear...this pic gives you an idea how your speedometer gets it's signal.
Install new rear seal and assemble speedo shaft into housing before installation
(There is also some felt and an o-ring)
Now were ready to move onto the front
Install race into tcase cone
Install bearing onto front haft of output shaft
Install 2/4 selector sleeve before you attach the front cone (w/front shaft installed) onto tcase
Now your ready for the Hi/Low fork/shaft install (more o-rings)
Install ball/spring/plug and test for feel...adjust plug if necessary.
It will be harder to move the selector w/o a leaver (no leverage)...you want it to feel SOLID.
Moving onto the top cover, if you want to improve the venting, here's a good option
Tap for a 1/4 NPT fitting
Your front 2/4 cover will have some felt and an oring.
Tried to save my old fork, but it wasn't meant to be
still looking for a good used fork...
Front
New Parking-brake Drum bolts are on the way...cheap insurance.
Even though the case install remains, I am really pleased w/this project.
If you get satisfaction from working on your own rig, and have thought of rebuilding your tcase...
I hope this thread helps.
Always refer to your fj manual for torque specs.
Rodney...what can I say,
I really appreciate you talking the time to show me how to re-Build my tcase.
This learning experience/opportunity is definitely one I will remember...
Thank you again,
manny
Scored the 2/4whl fork I was looking for...thank you Stockton swap-meet :D
Hi All:
Nice thread, "Manny!"
I'm surprised you are not including some sort of "t-case saver" in this re-build?
Regards,
Alan
Really nice write up Manny. I was looking as I am doing a rebuild now. I have a question about your bearing preload on your output shaft. You seem to have skipped this step by fully seating the rear bearing race and not using the proper shims behind the speedo gear housing. Did I miss it? Or is it not necessary?
Jeremy
Jeremy,
You may have noticed that the rear race does not have a step in the case, so it will adjust as everything everything is torqued.
Some people use a Fish-Scale to measure the Preload...others simply go by feel.
The Cruiser Tcases are pretty accurate, so if you continue to use the original rear output shims in your rebuild...you will be good.
I understand Orion cases are not so forgiving ;p
Preload is important...thanks for asking the question :D
manny
So, after the 2+ years, how do you like the 4spd conversion? Worth it? Would you recommend it to others with a 3spd?
Might be helpful to others....by far the hardest part of rebuilding a 3 speed case is removing the roller bearing from the main shaft. There's no way to grab it and it's in there TIGHT. After rebuilding multiple cases, this is best method I've found.
Break the inner race with a punch, it's not very solid and the roller bearings will fall out
Now the outer race will be stuck fast inside the main shaft. I use a high speed carbide cutter/grinder to split the race. Be careful when doing this, the idea is to ONLY cut the race
Groove cut in the outer race, ready to split it apart...
Use a very thin punch to get under the outer race and push it away from the main shaft...
