Ignition Shorting Issues 6/72 FJ40 (3 Viewers)
Good evening folks,
I have been having some issues with my 6/72 FJ40, and am a bit stumped as to where to go.
Around this time last year, I learned that my Fusible Link went bad after my FJ just stopped any electrical. My 40 has been running well until about a month ago, where all of a sudden, it wasn't turning over. That turned out to be a bad battery, but I also put in a new starter as my starter seemed to be making clicking noises but not turning the engine.
Fast forward to today, new starter, new battery, new day. Get those both installed, and he begins to turn again, and maybe 2 seconds in, dies. Turn the key again, nothing works. I figure that the Fusible Link went bad, but my wife was in the garage at the time and said she swore she saw a spark under the truck before it went bad.
I am scratching my head, as I am not experienced in Electrical Diagnosis. I recognize that a new fusible link is likely in order, but the fact that this happened twice in a relatively short period of time, I am not sure where to start. Does anyone have any tips?
Good evening folks,
Post some pics of the starter wiring
Just because you bought and installed new parts doesn't mean they are good.
Load test the battery. I put 2/O battery wires on my rig recently - what a difference The red pos + goes right to the starter, other pos attach at the battery clamp. I ran the black -neg right to the block and used the old 2 gauge wire from the block to the frame. I think there is a copper flat strap from the frame to the chassis.
You can work on the starter - clean the computator, make sure the brushes are good. I took the solenoid apart and flat filled the big copper disks to clean off the damaged arc spots. I think the info is in the factory manual and the haynes book.
You can test the starter with a set of good jumper cables, I like to do it on the ground. Clip one cable to the other so they can't touch then attach the other end of the jumper cables to the battery. Now connect the loose neg black to the mounting flange on the starter. Step on the starter to hold it in place - press the + red to the copper stud on the starter solenoid hard. Sparks will fly so don't do it on/next to combustible stuff. A good starter will lurch and roar to life plus the (bendix?) gear will leap forward towards the nose cone as to engage the flywheel ring gear. When you remove the + lead from the solenoid the bendix should snap back to the home position.
I think the fusible link is directional - if you put it on backwards it will fry - that is/was the electrical protection for people that hook up jumper cables wrong.
Free download manuals Land Cruiser Factory Service Manuals (FSMs) - https://www.cruisercult.com/factory-service-manuals
There's an earth strap from the chassis to your bellhousing - check that's there and in good condition. On my 2fs its held to the engine by the bottom starter bolt. Crappy connection at an end will spark. Fusible links are just a length of skinny wire with a fireproof outer, I replaced mine with aftermarket ones, have a read in my long thread.
When I have starter issues, checked the battery by load test it with the starter, check for loose connections, clean the terminals-both end with a wire brush, will somtimes oxidize. You also connect a volt meter to battery, applying a load should make the volatage come down a couple volts and climb back up to 12v after the load. I understand you already purchased a battery and starter but I'm suggesting this incase others have a similar issue.
To test the starter, I usually turn the key to the on position on the ignition sw. and I like using a remote starter. Should turn be able to start engine. If are uncomfortable testing it, try starting it with the key instead. You can also remove the starter and take it the auto part store, same for the battery And have them load test it.
If it clicks but does not start watch the volt meter as you put the load. I will use the booster cables and connect the ground to starter chassis and the other end to the battery. Try to start it. No joy, I try the same thing with positive side. If starts with booster cable as jumpers, you may have oxidized battery cable ends. If don't have a ground cable from the frame to the starter, install one, it does help. You usually see them on fj60s newer fj40s. Anyhow, cleaned the terminal ends with a wire brush. Or replace them like mentioned above. I usually make my own, I crimp them and put heat shrink over the terminal and cable. It's pretty easy to make them. I used a crimper from work but you call around and somebody should be able to crimp them or get one them fancy hydraulic crimpers from Harbor Frieght. I hope this helps, good luck
All,
Thanks for the advice and posting. Here are the photos of the new "direct replacement" :rolleyes: acDelco starter that I put in, as well as the original starter.
I will try and bench test my old starter as well. But two notes for the wiring. The new starter has a wire that has no attachment for my year 72. There is the ground, positive cable wire, and the ignition wire. The ignition wire and ground are likely original, but the battery cable is new as the original corroded through.
Update to folks:
I went into the garage out of curiosity to see if the battery would do anything on the FJ. I reattached the brake cables, and turned on the lights, which worked. Decided, what the hey, I'll try to start it with the lights off. It made a single chug, like a weak battery, and gave the ghost again, but in a far less dramatic fashion.
The battery was brand-new from the auto-parts store, I don't have a multi-meter (I will plan to get as you have all suggested, though those symbols on them scare the high-school math class out of me) but I do have a trickle charger. I will put it on the charger and see what happens. The charger is old school, so it has a dial gauge that shows 8 volts right now, so it is clearly low.
The dramatic death while chugging is confusing to me, but could be explained by a not full-strength battery.
Get one of those battery load testers too. You run a 12 V lead acid battery dead a few times they are about dead for good. When you go to buy a new battery watch them load test it first.
Alright so, tested the battery with a load tester and multi meter. Shows about 13 volts right now and shows the battery is good, also displayed in the good range. I double and triple checked. I may bring the battery to the AutoParts shop and see if my load tester is off somehow.
Turned the key for a few short seconds, the brake light warning light turned on, and I heard a click. Lived for about 5 seconds, then nothing again.
Did a resistance check of the fusible link, which showed .00 Ohms and a continuity test which beeped and also showed .00. So the fusible link doesn't seem to be the issue. (correct me if I am wrong). Also did it from the battery to the end of the fusible link, continuity and resistance checked out.
Edit: Checked Fuses, and replaced for good measure. No progress. Battery still steady, checked continuity with starter wires and everything checks out. The car is acting completely dead, no electronics will work.
I cannot help but to notice, the small ground wire that is bolted to frame(next to the brake line) may have shorted. Looks like the insulation is melted. Not sure if was previous failure before you got it. I would replace it. Unfortunately when wires short out like the get oxidized. It's to replace them.
The ground cable going to engine can be removed an clean the terminal end with wire brush.
And the last pic, I see the broken insulation. You can clean it and slip heat shrink over it if the terminal let's you. If not use electrical tape and coat it with silicon. I would open the starter and clean it. Oil has probably seeped into it. Inspect the the brushes while at it. Last thing it's not a gear reduction starter which us ok. The fj60 got them. I replaced mine with on from a fj60 starter. The advantage using a gear reduction starter, it uses an lot less current to turn the crank.
Have you checked the ignition switch harness? Do a continuity check. I don't think your battery is draining since you said you had 13 volts. Usually a relay will get stuck in the closed position causing the battery to drain over night. You may have bad/oxidized connections, may need some cleaning. Go though the whole circuit and start cleaning terminals. Also reseating connectors to the same circuit will help. Sometimes people ignore grounds but they are just as important as the positive side of the circuit. Last resort, verify you have good connections at the fuse box. Disconnect the battery when you do this kind of work. Good luck.
FJwagon;
I checked the ground wire from the frame to the starter. There isn't any fraying or melted issue with the wire. I cleaned the dirt off and the yellow line and some old crud seems to be the cause.
I did bench test both new and old starters. They both rotate, but I noticed that they do not push the gears to the end of the starter. I am assuming this is part of the problem with starting, as most videos I see the starter throws out the gear to the fly wheel and retracts when the ignition no longer turns.
If this is the case, it sounds like I need to send the new one back anyway... I think it was mentioned on how to restore the original starters (which I would like to do) so I will try to identify threads that talk about that.
I haven't made time to look at the other circuits, but I will give that a shot whenever I get the starter issue figured out...
All;
Is it common for no electronics to work when the starter fails? I believe alternators can, but I didn't think starters could? The fusible link reads well, but I wonder if I am reading it wrong...
Well, Everyone can disregard.
I decided to put the old starter in to see if I could at least get the electrical going and now he runs again. So clearly a battery issue 1st and likely cleaning the grounds, then the new starter 2nd.
I would like to refurbish my original starter, especially with that wire showing, so that'll be on the next to-do list.
Thanks for all of your help and I learned more about electrical that I knew before so that is a win.
