Well its a LT swap not a LSThis may be an ignorant question, but what is the rationale of the LS swap?
From my neophyte point of view -
Pros: It's a GM platform, creates much more power/torque and keeps up with modern traffic, takes gasoline, common parts availability and mechanics are much more familiar with working on them.
Cons: It's a GM platform and mechanics are much more familiar with working on them. You get rid of a lot of the reliability these platforms have a pedigree providing.
Is this the 30,000 ft view?
Awesome write up. MUCH more detailed than I was hoping to get. Thank you!Well its a LT swap not a LSlol I kid I kid
Rationale is
Now #7 does contradict your cons but the reasoning is most people do a low mileage V8 swap when their yota I6 is up there in miles so you are gaining lots of time on that motor before something needs to be done. Also your cons are super accurate GM V8's, especially from the gen III to gen IV models are extremely reliable. I'm not going to say a LS will run as long as a 2uz every time but i've seen loads of examples well over 500k and still running fine, hell one of my old work trucks was around 663k on a Gen 3 5.3. Their sensors aren't as robust as denso made yota ones but mechanically a GM based V8 will last a long time. Mechanics are much more famililar with them but when you compare the sheer number of them to the amount of I6 yota motors that only hit the US market in forklifts or landcruisers, its just a numbers game. The Gen IV and V motors came in the same years, Chevy and GMC vans, Chevy and GMC Trucks, Chevy and GMC SUV's, the Corvette, the Camaro, the Impala, the Caprice, etc...... The Gen III came in all of those along with loads of Pontiac, Oldsmobile, Saab, Isuzu vehiles. Most people with a cruiser will do all their PM on time with quality parts. Large amounts of the people out there driving tahoes will run 10k over the oil change recommendation and throw the first chinese made part they can get for the lowest price on there. Even the Gen I and II engines are stout. Ive had tons over the years and never had to rebuild one or do any major work that wasn't me doing it a huge power increase. I've had 5 suburbans now and 289k was the lowest miles on one when I sold it. All original motors.
- more power
- more torque
- better mpg
- newer trans with better ratios and more gears if going auto, cheaper and easier to find trans if going manual
- parts availability
- cost to do a GM V8 swap is tiny compared to cost to do yota V8 swap and you get more power doing a GM swap anyway
- and reliability/parts availability
The cons of the swap is really the trans despite being a pro at the same time. The 4L80E is bomb proof but doesn't have the most amazing gear ratios and only 4 forward gears. The 10L8/90E is also bomb proof and gives you great gear ratios along with 10 forward gears. However mating the newer trans to older GenIII and IV motors gets a bit complicated. the 6l and 8l have good ratios and have a good amount of forward gears but do have some flaws that may want to be addressed so you don't run the risk of having to pull it back out at some point. Generally lots of the issues have to do with heavy towing and not doing PM on it but a TQ converter change is recommended on both. The 4l60E is a pretty terrible trans in terms of power holding ability, gear ratios and only 4 forward gears. You can spend a bunch and get it fixed up but they are still a pretty weak design. That same work truck I had was on its 4th 4l60E trans at the same mileage.
Hope that answered some questions.
I've always wanted and thought that a diesel swap was going to be it for the 80 but right now I need the easiest thing possible and MPGs with DI on the V8's has gotten so much better it is just what i'm going to go with now.
There was but in another thread lolz.Any updates on this build?
Putting this in here.Not to hijack Eric's thread here, but 10 speed? What's wrong with the 8sp (6L80e I assume?) you have already?
Looking good @fourtrax
Didn't know that. I meant to type 8L80, not 6L80. That seems so complicated to me lol.Putting this in here.
Hey Ramon, the 8spd is the 8l90e. The newere ones 2019+ have some internal differences from the older 8 speeds 2018 and earlier to fix some known issues. Unfortunately these updates make them very hard to use for a swap (don't ask me why its all friggen magic to me when it comes to the TCU's in these things) So my choice is to either buy an older upgraded valve body along with an older TCU to make it work or for the same price or less I could get a 10l80E which is a better/stronger trans with 2 more gears.
Yeah I was hoping to have all the stuff ready for the 80 when it got here but grabbing the wrong trans combo set me back. That's the issue with such new things I guess one source says its fine and another says no. If it wasn't for the TorFab kit being pretty much a complete bolt it I would have done an older LS.Didn't know that. I meant to type 8L80, not 6L80. That seems so complicated to me lol.
I'm guessing my next iteration in Dozer is going to be to go auto and it will likely be a 6L80E, for which the Terminator X can be used (with an upgrade module) or as is with a 4L80. Good luck brother, it all gets wonky after the 4series anyway. The whole tapshift sfuff is pretty cool though!
Maybe a nod to HG awareness month?Not so sure about the sign above your beloved 80…
its to give me strength when I build my IAG closed deck subaru motor i've got on a stand. lolNot so sure about the sign above your beloved 80…
