if clutch is in backwards will it still disengage? just installed a new clutch now I'm having this problem; the tranny shifts when engine is off. When engine is running I can not put it into gear (with clutch pedal all the way down). the clutch pedal feels normal, the hydaulics are obviously working as I can see the clutch fork move (looking through the t'case shifter hole). ALSO.. today I got under the truck, removed the clutch inspection cover and had someone step on the pedal while I watched the clutch... It was disengaging the flywheel (putting a gap between clutch plate and flywheel). Would the clutch move like this if it were in backwards? I have yet to do the inspection while the truck is running and in neutral. Is there something to look for that will tell me more by inspecting while the motor is running?
Sorry to beat a dead horse... I figured I'd start a new thread with my specific problem and try all suggestions. Hoping to come up with ammunition for this next weekend.
