Now I'm kinda interested in this. Why did I comment? I don't even have an 80 or want a RTT. But it's kinda fun in my down time to design stuff. Assuming the width is 4 feet?? makes life easy if that will work. And 8 feet long. I can nest all the parts in 3 4x8 sheets. Plus you'd still need at least 2 more full sheets. And some other small pieces of solid wood - I think Pine would work, but I tend to prefer to use a harder wood like Maple or oak if available. I also really like to use Home Depot's exterior PVC trim. It's flexible, works great with heat to soften, and impervious to just about everything. Plus it epoxies well to fiberglass.
So I think the total materials list would look something like:
3 - 4'x8' 3/8" plywood (lower subframe and cap)
1 - 4'x8' 3/8" plywood (bed subsurface)
1 4'x8' 1/8" Luan (Bottom curved board - probably optional, but I'd use it)
8 yards of 10ish oz/yd or ~450gsm 45*/45* biaxial fiberglass fabric 60" wide ($150)
3 gallons of Epoxy Resin - or polyester/vinylester ($150)
20 yards of 4" 6oz biaxial fiberglass tape. ($25)
5 yards of 4" 6oz uni fiberglass tape. (not sure if this is necessary - I'd have to think about it) ($25)
Some volume, maybe 1 gallon?, of fillet powder mix, anything works - wood flower, phenolic micro beads, ?? basically it's just filler to thicken the epoxy into a paste. The purpose of this is to make the interior corners rounded so the fiberglass lays across the curve. ($50)
8-10 yards of Peel Ply (Walmart dress liner fabric works awesome and only costs $2/yd!) ($20).
Whatever finish you decide. I like 2 part Urethane, but any boat top paint would probably work just fine. Even exterior latex paint would probably work pretty well for a long time on these. They wouldn't get the wear of a boat. And the epoxy is waterproof, so it's really just for looks and UV protection of the resin underneath if you don't use UV stabilized epoxy. You could leave it unpainted too if you really wanted. If you're looking for a pro quality finish, you'll probably need to think about some sanding fillers, high build primer, etc.
1 box of Harbor Freight chip brushes. ($15)
Assorted disposible containers for mixing epoxy. ($25)
Lots of rubber gloves. ($10)
Hinges
GAS shocks ($150)
Fabric ?? ($500)
Bedding?
Mounting hardware to the drip rails
This is a pretty good idea of a materials list and costs I've added to the stuff that most people who haven't done it before wouldn't really have a good idea of costs for. I did a simple layout of the parts and here's an idea of how you'd lay them out at home to nest most of the stuff into two sheets. And realistically as I drew this I thought that you could probably get away with having only 1 sheet cut by a CNC router and do the rest yourself with regular home tools. And obviously if you want to spend some time with a jig saw you could do it all at home pretty easily. The key with a jig saw to do it fast would be to cut one of the parts very well, then use your palm router with a following bit to make the rest. No sense in doing the hard part multiple times. (Also keep in mind this is just a random drawing I made up in a few minutes. It's not matched to any vehicle, just using a 4x8 size as a starting point because it's easy and I'm not going to spend a lot of time doing more drawings for an imaginary project.
Edit: Looks like the rails are about 52" wide, so this wouldn't fit even if I did make a finished set of plans.
