Just installed. Like @01gmentioned, the spray pattern is lower than stock, but I prefer it that way. Keeps it tidy. Works great.
Thanks for the part number!
So yeah, turns out that toyota part number 8538134030 is an exact fit, spray pattern is also a very welcome upgrade over the original two stream nozzles couldn't take pictures as it is dark outside but will update tomorrow
I just installed these and this worked great for me. I added the valve mentioned as well right before the bifurcation to stop fluid from running back to reservoir and it is perfect. Nice wide pattern although hits about 1/3 of the way up the windshield. Fine for me based on a non-OEM version that I tried prior.So yeah, turns out that toyota part number 8538134030 is an exact fit, spray pattern is also a very welcome upgrade over the original two stream nozzles couldn't take pictures as it is dark outside but will update tomorrow
Based on many discussions and opinions from a few different threadsI went with OEM
What do you mean that the pattern is adjustable?It is my understanding that the spray pattern is adjustable on these. I believe you can just use a sewing needle to adjust the spray direction.
Ah ok... I thought you were talking about adjusting the spray pattern of the FJ Cruiser/Dorman style ones that are a fan vs. the 3-stream...I believe that the 3 nozzles are able to be aimed with a something small and narrow like a sewing needle. You just stick it in the nozzle far enough that you can rotate the ball the nozzle is in around to where ever you want it to point. So if the spray is too low on the windshield, it can be directed higher.
Yup... on the short list of upgrades before winter hits. My 3-stream is actually a 2-stream on my 98 so don't know if that is because one is clogged or what, but it SUCKS!Oh wouldn't that be nice! I much prefer the misting style.
Not on these that I used. It is a wide angle mist that hits the same height as stock but much wider coverage than the 3 spray design. I much prefer these.It is my understanding that the spray pattern is adjustable on these. I believe you can just use a sewing needle to adjust the spray direction.
