I just bought some Method 305 NV in brozne (1 Viewer)
Those methods weigh 32lbs each, not sure how much stock wheels weigh but they're pretty similar, you shouldn't notice that much of a difference. The truck is slow to begin with lol
Getting alignment done since i never got it done after sensor lift.
You’ll want to perform a Zero Point Calibration if you havent done that yet.
Ill try that if it starts acting up again.
I just drove the car away from alignment and its 100 fold better and insanely smooth with no issues. The drive is great but it seems i should change my steering rack bushings because they are worn which ill be looking into right now.
Pics from today
Flex her and stuff her, see if she rubs.
Nothing rubs because the tire size is the biggest without rubbing ( I shoulda got bigger tires :P). One thing that annoys me is when it starts to lean a little it feels like its going to roll so easily. Whats the degree of the angle thats safe or do i have to buy new suspension because its old and too soft. I literally feel all the weight starting to come over and becomes unstable at what seems like 20 degrees.
How do i flex her?
When i drop that wheel down the entire rig wants to roll over i feel the rear lifting etc.
What suspension setup is that?
those look great was looking at the 17s for my 100
That is the 105 variant that the rest of the world has access to.....solid axles front and rear as well as a diesel option. Alas, here in the States, we can only do a super expensive axle swap and lots of work to convert from IFS to SA.
thinking about pulling the trigger on a set of five of these for my 1998 landcruiser with a 2.5 in lift. what do you guys think 17" or 18" gonna buy tonight im leaning more towards the 17"
i have a Dark Green 100 and i think the bronze would compliment it nice. is there any kid of benefit with a offset? thanks everyone
it looks better
  • Like
Reactions: JPS
How is the rubbing at full articulation?? I have an Ironman lift and thinking hard on this wheel but heard the offset limits going to large sizes like a 295/70 without serious rubbing. Any thoughts? Also @brandon12777
I've never rubbed im 285/65 i think
Thanks for the quick reply, do you think you could stuff an extra 1.6" of height and 0.5" of with on those? I wouldn't mind minimal rubbing at max articulation in the rear. Could solve that with some spacers for the bump stops. But if the only path is through the fender.... then I might have to stick with the safe tundra 5 spokes I have haha Brandon12777 pictures look like the front might be hard pressed to stuff a bigger tire.
