OK, just noticed on my 14’ when I turn my heat on, the vents blow the same cool air from the LOW setting all the way up to 85 degrees……no change at all in the temperature of the air coming out, it’s like it’s stuck on LOW temp. Once I turn it to HI heat, hot air comes out……like HI heat hot air, like it should.
I searched on here and all over Google and other Tundra/Sequoia forums……nothing. It all comes back to HI fan settings and blower motors or just no heat at all stuff………nothing specifically to the HI temperature setting problems.
Could it be a blend door thing? Is there a resisor or something that the temp setting knob controls that could be bad? I’m pretty clueless when it comes HVAC stuff and usually have the setting on HI or LOW.
