How do you "cook your brakes" going up hill?
... After cooking my brakes on a hill climb, i'd like to be able to turn it off as well.
Yukon LX said:Why do you think it will help you not having it? If you go full throttle it turns it off as well and goes open open.
I think my problems of "no go" in deep sand may be attributed to Atrac. Maybe that's not it, but I want to turn everything off to start from basic if possible.
never found a time I needed to disable ATrac....I have driven in sand, mud, up steep hills, etc. Light application of brake disables it as stated for slow speed movement such as ice....and 100 also has 2nd button for starting in 2nd gear only to help prevent wheel slippage due to torque, etc.
lots of people also dont know how to use ATrac...it requires constant throttle, not wide open, enough to keep rpms up...and then working steering slightly. I have had tranny get hot on long climbs before but never noticed brakes cooking. For the 1% of the time the ATRAC may not be ideal...I think I will put up with that possibility given all the advantages it offers.
I think my recent problems of "no go" in deep sand may be attributed to Atrac. Maybe that's not it, but I want to turn everything off to start from basic if possible.
Sometimes I can floor it in drive or reverse and nothing happens. Wheels don't even spin. Zero wheel movement, the truck just revs. A number of people said it must not have been in low or high or in gear. Trust me, I got that. My buddy's FJ did the same thing in the same deep sand. When he turned off Atrac it popped right out and wheels turned. I had to dig and lay Maxtrax like crazy. Not as fun as blasting through deep sand dunes.
The most embarrassing part, my other buddy's completely stock manual Xterra on OEM tires drove he same deep sand effortlessly. Didn't even have to air down. Makes you think about all the mods made to my truck and which ones actually improve "go" when the terrain gets rough...
Isn't the alternative not making it up the hill?
Because there are times when wheel spin is needed/wanted,
then all you have to do is put down the skinny one to the floor and problem solved. Atrac will not stop you at wide open.
