How To: Replace your Upper Steering Column Shaft (2 Viewers)
Portland, OR
Website
www.shapeways.com
My steering was ratting over bumps and had annoying rotational play, or a "dead spot". Wandering while driving too. The cause was wear of the collapsible slip joint within the upper steering shaft. Turning the wheels with the engine off stresses the joint and can loosen it over time, in my case 290k miles and two previous owners. Others have posted about it and from what I've read it's an issue with other Toyota models.
I replaced the upper steering shaft and related small parts and the issue is totally gone. Steering feels tight now with no play or clunking anymore. Parts cost was $214 total. "Shoulda done it a long time ago" is an understatement...
It's super simple to check the shaft for play: Reach under the dash above the brake pedal and feel for the shaft junction circled below. When you wiggle the steering wheel the small shaft should mimic the movements exactly. If there's any play between the steering wheel movement and this shaft it'll be very obvious.
Here's a step-by-step procedure if anyone wants to tackle the job themselves. Took me about 4 hours including taking pics & notes along the way. Parts listed are for a 1998 LC, so check your vehicle's year/model for correct P/Ns. Enjoy!
  • Upper Steering Shaft Installation.pdf
Excellent write up, thanks for taking the time. Will be very helpful for me and others with this common issue.
@Ayune ... Jim... your pdf is a work of art. Doesn't it make you wanna do another steering rack so we can take picts of all fifty some steps???? ;) Just throwing it out there.... Ill be in Oregon on the 25th of July :) LOL
Looks awesome bro!!!! Kudos
Thanks. I did my steering rack at a pay-by-the-hour DIY garage with a lift, so I wasn't taking the time for pics! Plus there was ATF fluid absolutely everywhere, my phone would've gotten completely jacked up. The column was a much cleaner process.
Bumping this awesome DIY! Clear instructions and great pictures. I just followed it to do mine this morning in about 2.5hrs. A couple of things I noticed:
Diagnosis for this issue:
Lie down underneath the steering wheel and grab the universal joint (at the firewall) by hand and turn the wheel with the other hand. You should feel the dead spot between your two hands. If so, it is the upper steering shaft issue. I've also heard of the intermediate shaft being the issue so its good to isolate before buying the parts.
1. (PAGE 3) Steering wheel puller thread. Mine was M8x1.25 instead of 5/16-18. No big deal. The loaner set from O'Reilly had both.
2. (PAGE 13) Removing switch assembly. I found it difficult to access the two 10MM hex. It was easier to remove the 3x philip screw from the sides.
1940193
1940194
3. (PAGE 15) Pressing on new retainer clip. 18MM socket was not big enough for me. It bottomed out on the taper before being able to press the clip in all the way. 19MM work well. This might be down to differences in socket design. I would test your socket on the old shaft to make sure it slips down all the way.
4. (PAGE 17) Pressing in new plastic bushing. I separated the flange from the tube to get better access for knocking in the bushing. Not really necessary but easier get a dead-blow hammer to evenly press it in.
Other than that, again great instructions. This is what makes IH8MUD great. Thanks again.
Thanks Ayune for the easy to follow directions. My steering is noticeably tighter now. The extra information @dy9213 provided was super helpful as well.
I ended up breaking the little Tilt Lever Link because as I was trying to put it into place I moved the Tilt Steering Lever which applied pressure and snapped one of the ends off. @Ayune wasn't lying when he said to "finagle and wiggle it out". Just spin it between your fingers and it should be able to pop right in. Luckily I was able to get the part the next day from the local Toyota dealer (only $3, and $0.90 if you order it from partsouq.com which is where I ordered all of my parts from for this project - might as well add it to the list at that price. If anyone in Portland, OR is doing this I have an extra one I ordered just in case, hehe).
World class write up, my dude. Gonna tackle this next week. The lube you mentioned on shaft parts; white-lithium grease?
Great write up, much appreciated. I followed them and replaced all components. It helped a ton, especially on just normal steering feel and tightness.
Question though, when I hit bumps, I still get a real "loose" feedback, what's the other major wear component in this line down to the steering rack that people have found to help?
Excellent write up. Solved my “click” or “rattle” when turning that was driving me crazy. Took me about 4 hours total.
@Ayune thanks so much for this amazing write-up! It made it so much easier for me to get this done. It took me about three hours today, and eliminated a huge amount of play from my steering ('99 w/300+k).
The only thing that I might add that I found easier, is that I used a ratchet clamp
to press the bearing/spring onto the shaft. I broke off a piece of wooden chopstick and used that between the clamp jaw and fork ends. I still used the 18mm socket. This just seemed easier than pushing the socket with my body weight, and a couple squeezes seated the snap ring.
Did you get this fixed or figured out a solution? I just did this replacement and am getting a "chattering" over bumps. Any ideas? I feel like it is still coming from the upper shaft. I am holding the u joint and shaking the steering wheel and can hear it behind the wheel.
How's your rake? I had my front end too close to the height of the rear for a bit and it felt wonky like that.
Rake is good, this issue started after I fixed the slop by replacing the upper steering shaft. Thanks for the ideas though. It's driving me nuts and would do anything to fix it. lol
I still haven't figured it out, unfortunately.
My slight noise and shimmy is from the U-Joint at the lower end just before it goes through the firewall.
I actually mitigated it slightly by using two large zip-ties around it to help “tighten” it up a bit, lol…
I did that after realizing I could put pressure on it and the noise would stop.
If it comes back I’ll replace some hard bits, not looking forward to it but I am very thankful I have a printed copy of this repair.
You just dont get any better of a discription than that!
Thanks, I'll try that too.
Not sure if yours feels like this but as soon as I'm on anything but a hard smooth paved road, my steering wheel feels like it goes from normal (tight) to loose and squirrely like if I had major steering wheel play, but my steering rack is new OEM, and I did the repair in this thread so I'm thinking it has to be the U joints or splines somewhere from the steering wheel itself down to the new steering rack. I'm not above just throwing parts a problem (ex, the notorious clunk) if I have to.
